Deej's hard starting solution
Old Aug 31, 2010 | 12:03 AM
Drill the starter jet out with a .018" or .019" drill bit by hand and be done with all cold start problems no matter how long the bike sits.
Old Aug 31, 2010 | 12:25 AM
wildcard's Avatar
Just drill a hole in the float bowl so the gas will run out without the hassle of using the float drain. Problem solved !!
Old Aug 31, 2010 | 03:03 AM
Fishfinder's Avatar
Default Hard Starting
Thanks alot Wildcard but I think I will opt for door #2.
Old Aug 31, 2010 | 03:08 AM
wildcard's Avatar
So i'm guessing you don't want to hear about my compression relief mod so the engine turns over easier ?
Old Aug 31, 2010 | 05:43 AM
maninthesea's Avatar
I thought compression relief was standard on the 250s & sf? Also know as ACR (auto compression relief??)
Old Aug 31, 2010 | 07:10 AM
wildcard's Avatar
I was making a joke.
But if you really want the engine to turn over faster i would recommend removing the spark plug. The motor will spin like a sewing machine then
Old Aug 31, 2010 | 12:54 PM
Fishfinder's Avatar
This is what makes this forum so great. You get a lot of good advise and also some great one liners to use at the next party. I wonder why I don't get invited to many parties anymore? Must be the economy?
Old Aug 31, 2010 | 02:15 PM
hahahahahahahahahahahaha Dude that made my morning. good stuff!
Old Aug 31, 2010 | 03:10 PM
BigGreenBastard's Avatar
My bike is completely stock. When its cold and hasnt been run in a while I try to start the bike with the chock but have no intention of starting the bike if that makes sense. I only push the starter for a few seconds, just enough for the bike to turn over 2 or 3 times. Then I wait about 15 seconds and try again and it starts right up. Before I came up with this method I was holding the starter for up to 5 seconds trying to get the bike to start on the first try.
Works for me.
Old Sep 1, 2010 | 12:10 AM
GaryC's Avatar
since i have rejetted i can let my bike sit for several weeks and it starts right up.
I don't even turn the gas off when i park it.
I don't understand what the problem is if you have the bike jetted properly.
