Deej's hard starting solution
Old 09-01-2010, 06:45 PM
jckid's Avatar
Originally Posted by Fishfinder
Do you have the number for the Iridium Plug. Thanks
I don't have the part # handy right now, but the one I got is an NGK Iridium plug. You can probably look on their website. I think it's the same number as the stock plug which should be listed in the KLX manual.
Old 09-02-2010, 03:35 PM
Ranger Ron's Avatar
NGK CR8EIX
Ron
Old 09-02-2010, 06:12 PM
Fishfinder's Avatar
Smile
I installed the Iridium plug. Backed off the pilot screw (#40) to 2 1/2 turns. And gave the carb a good going over with carb cleaner. I'll take that back, a mild going over. I opened up the drain screw and shot the carb cleaner through both vent hoses on the sides of the carb. My question is, did the carb cleaner go through the jets or only flow into the float bowl? I hope I do not need to remove the carb from the bike again. I got lucky the first time. Put it back together and it actually ran. Now if it will only start reliably.
09klx
11-04-2010 11:49 PM
Finger Mullet
12-04-2007 11:24 PM
Nobrakes
08-23-2006 06:51 AM
klxstiffler
07-05-2006 08:24 PM
Nobrakes
05-27-2006 08:35 AM
Quick Reply: Deej's hard starting solution
