Dead battery? Help
Old Jun 9, 2016 | 12:21 AM
motopat's Avatar
Default Dead battery? Help
Hello everyone,
I have a supermoto that won't crack because of a dead battery. I just purchased a new battery 5 days ago and went riding for 2 days straight. Towards the end of the ride, my bike died. Lucky for me, I was riding with a buddy and he had jumper cables on him. He jumped the bike and we got it home without a problem. During the ride home, my dash (speedo, blinkers, revs, and neutral light) were all flickering on and off. Then eventually just turned off completely like it would when the battery is dead. So I got home and then hooked up my battery to a charger and the green light on the battery came on. The green light indicates that the battery is charged? I just don't understand. Can anyone help me?
Old Jun 9, 2016 | 12:35 AM
durielk's Avatar
Check that the battery is grounded to the frame.
Jct842's Avatar
Need to get battery checked with a load tester. Sounds like it has a weak high resistance cell in it.
Old Jun 9, 2016 | 07:45 PM
motopat's Avatar
I tried. There are two wires that get connected on each side of the battery and I alternated those just in case I had them backwards but nothing worked. It still wouldn't show my dash before I even cranked it. It doesn't make any sense? Is there anything that could be wrong with my bike because I just bought a new battery five days before this new one "drained".
Old Jun 9, 2016 | 07:53 PM
durielk's Avatar
Maybe the battery is bad.
Old Jun 9, 2016 | 07:58 PM
motopat's Avatar
So did I buy a bad battery or is my bike not keeping it charged... Like why is it draining so quickly?
Old Jun 9, 2016 | 09:01 PM
Jct842's Avatar
You may very well have damaged things doing that, I would take it to a shop before more bad things happen. The rectifier/regulator can easily be blown doing that as well as the dash meters. john
Old Jun 9, 2016 | 10:27 PM
durielk's Avatar
I really don't think he did what it sounded like. I think he just put #1 in #2 position on the same post (not change posts + to -).
But, start with the easy things to check and just go through them. If you don't know, at this point I would recommend to take it to the shop. You can't learn everything over the internet. You can try, but it is difficult.
wackychung
Jun 20, 2009 11:00 PM
deej
Nov 3, 2006 01:19 AM
05zx_6rrider
Oct 1, 2006 04:29 AM
SNYPERDON2001
Sep 4, 2006 05:13 AM
Nobrakes
Jun 28, 2006 07:00 PM
