Could Someone Please Check my Valve Shim Calculations?
Old Mar 19, 2015 | 03:39 PM
ol'klx-er's Avatar
On the tight end of spec would have the valves open the longest = more intake in, more exhaust out. Sounds good to me. Setting them at the loose end means having to adjust less often though.
Old Mar 20, 2015 | 12:12 AM
MaximusPrime's Avatar
My bike starts and runs better with the valves on the loose side. Why is that? It was the only change I made and when I rolled it out on a 60º day it fired up w/o choke for the first time ever.
I set the valves to the loosest spec I could get to keep from doing it as often, since I have to check them twice a year due to mileage. Not sure my reasoning is correct. In reality I've only changed shims 6 times - the intakes were first, then 7500 miles later I did both intake and exhaust because I wanted the valves to all be at the same spec. Been good for the past 10,000. We'll see soon enough.
Old Mar 21, 2015 | 09:15 PM
mid-life crisis's Avatar
I just set them loose in order to buy more time. I never really thought about performance gains, and I didn't realize that it could make a difference depending on where you are within the specified range.
Old Mar 22, 2015 | 07:06 PM
zomby woof's Avatar
In theory it does. In practice, it doesn't.
Klxrelic
Feb 3, 2025 04:16 PM
MaximusPrime
Jan 5, 2016 11:29 PM
klxkiwi
KLX300R
Feb 10, 2014 03:43 PM
krntl13
Jun 25, 2006 06:49 PM
