Convert KLX 250 to EFI?
Old Apr 22, 2012 | 10:33 AM
bush pilot's Avatar
The carb is much easier to tune for power.
Guys here in Thailand are ditching the efi for carbs.
Old Apr 23, 2012 | 08:25 AM
willb's Avatar
From: Cheshire, in between the Welsh hilly bits and the Peak district hilly bits - just about in the North
If the European Union have there (alleged) way we will be banned from doing anything to our bikes that changes them from stock - no power train mods ~ air filter all the way through to the rear chain and sprocket; Mandatory ABS; no body mods. (Of course there may be some scare mongering about this - in UK we do love to only be in Europe when it suits us and whinge like **** when it does'nt)
Still better buy some carbs pronto, just in case? Or ignore EU regs like most of the rest of our European cousins
Old Feb 24, 2021 | 01:45 AM
Scorpioboui's Avatar
Originally Posted by JoelThailand
Don't do it.......get a TM33 pumper carb & have a blast!
Speaking from the Asian & Australian EFi market, it's hard enough getting the MAPPING right without the use of piggyback controllers or fully programmable ecu units, like I run. Our bikes come out of the factory EFi & can still be a pain in the a$$.....but when they run sweet, they definitely run better than a carby.
so where should I start jetting wise. I swapped my z125 with a klx motor and am getting the tm33 pumper. It's stock motor with exhaust and intake.
Old Mar 30, 2021 | 01:10 AM
Sid Post's Avatar
Originally Posted by linkin5
The dyno's I've seen from efi bikes are about the same or weaker than the carbed ones, they might start better than the the carbed ones in cold weather and that would be a plus.
Absolutely! My carbed 2007 model is a B!*** to start on a cold morning! That is my major gripe against the older carbed KLX's!
Old Apr 1, 2021 | 10:50 PM
Klxster's Avatar
There are "fixes" for cold start problems.
The newer Dual sport KLX EFI's have a build-in (programmed into the ECM) power killing detune that cannot be deactivated ( at this time ) ... Thus, performance above 7500 rpm is far inferior to the carb'd KLX's..
Old Feb 11, 2024 | 05:35 AM
Max I's Avatar
Originally Posted by wildcard
Don't you know that EFI adds 20hp ?
Will the engine not run cooler at low ground speed?
Old Feb 11, 2024 | 05:48 AM
Max I's Avatar
For what reason? The carb works just fine.. Unless you're doing some crazy elevation changes or something.. .
I could think of about thirty better ways to spend the money on the bike!
to make engine run cooler
Old Feb 11, 2024 | 02:32 PM
  #28
If it wasn't such an old post I'd have said they should simply sell it off and get a new KLX300S or the like. With electronic stuff that is virtually always non-returnable and quite expensive, it would be a total crap shoot to try to retro-fit.
I will say it's a shame bike fueling is so one-off on every model that there can't be a deal done like cars. Street rod guys can buy a throttle body EFI setup that will actually adapt and learn what the engine needs are as the car is driven, after an initial setup. Sure would be cool if a 36mm throttle body with a self learning ECU or computer unit could be simply bolted on, a few numbers tweaked then let it learn.
Old Feb 14, 2024 | 06:44 PM
  #29
cycloholic's Avatar
Originally Posted by willb
(if you have a EFI bike try stuffing a short bit of stiff wire across the outer terminals of the clutch handlebar switch, make it look descreet and be amazed at the new bike you've got. Just try not to start in gear with sidestand up, only do that once thou') - if it is not for you its a 5sec convert to standard.
what??! explain!!
Old Feb 16, 2024 | 10:53 AM
  #30
cycloholic's Avatar
Klxster
Dec 11, 2020 03:05 AM
rickypanecatyl
Mar 5, 2012 09:22 AM
armycopter
Feb 26, 2009 12:14 PM
woobie
Apr 23, 2008 04:01 PM
