Check Your Exhaust Bolts
Old Dec 8, 2006 | 07:41 PM
cwgoff's Avatar
Default Check Your Exhaust Bolts
Alright folks, time for a little preventive maintenance tip. I was doing some work on my bike last night (installing KLX300 tank - pics to follow), when I decided to give a few things a once over. Man am I glad I did. Of the two bolts holding my exhaust to the frame, once was gone & the other was on its last thread or two before going bye-bye. Needless to say I had overlooked our good friend Senor Locktite on these bolts when I installed the Muzzy. Anyway, just a reminder that blue Locktite is your friend, and go check your bolts.
You'll be glad you did.
Old Dec 8, 2006 | 07:46 PM
Default RE: Check Your Exhaust Bolts
i havent had any trouble with any bolts.... cant say i have ever used locktite either.... i must be special
Old Dec 8, 2006 | 08:14 PM
I think the dried mud encasing your bolts hold them in place, ems.
Old Dec 8, 2006 | 08:22 PM
DJFields's Avatar
ORIGINAL: Nobrakes
Seiuosly though the loctite (blue) is a good idea especially of the fasteners we tend to get into alot, like the seat bolts. Be sure to use only a driop as thats all it takes.
Old Dec 8, 2006 | 11:13 PM
UTRoss's Avatar
I interestingly found my header bolts pretty darn loose (close to hand tight, hand as in by hand, no wrench!) when I went to inspect/grind that pesky weld bead on the stock header. Other things I have found so redicullously tight I can't loosen them - front sprocket retainer nut for instance...
Old Dec 9, 2006 | 07:54 AM
tremor38's Avatar
Some of my friends tell me I have a screw loose, but accept me for who I am, so why change now?
ORIGINAL: cwgoff
Old Dec 9, 2006 | 08:45 AM
MaverickAus's Avatar
ORIGINAL: EMS_0525
Thats cause your bike doesn't get ridden .... its always in the shop ....
think I'll hide now
Old Dec 9, 2006 | 12:13 PM
Hey now.... I rode it yesterday to the gas station being 22 degrees, then later that night after i got the big gun back on i went around the block, i think it was around 17 degrees
stephenmarklay
May 27, 2012 06:15 PM
kgwld1
Dec 12, 2008 12:37 AM
Knivez
Sep 14, 2006 08:22 AM
Knivez
Sep 13, 2006 06:49 AM
Shibby
Sep 23, 2005 05:35 AM
