Case saver
Old Mar 18, 2013 | 01:58 AM
Default Case saver
Sometimes you gotta run with it when the inspiration hits you. I made this up Saturday afternoon after getting the bug. This is my second try at a case saver. I ended up not liking the first one I made a couple years ago.
Running the stock cover in many of the heavy clay mud places I ride. The mud gets jammed in there, and starts coming out the holes in the plastic cover like play-doh.
First version is laying on the left. Cardboard template for the new one. Worn out diamond grinding wheel provides the raw aluminum stock. TNC will call me cheap again.
Bandsaw cut out.
Beltsander cleans up the saw cut.
Bandsaw again for the notch. Files to clean up the cut to an even thickness (within .005).
My handy $400+ "extra crankcase" for easy fit checks.
A little wet sanding
A little polish. ( I may take it back to the sanded finish, not sure which I like best. )
On the bike.
Dan
Old Mar 18, 2013 | 02:10 AM
Pictures of my first one. I don't like the pinch point this one creates. You could really get a rock jammed in there.
The prototype I made has taken a few hits.
https://www.kawasakiforums.com/forum...-models-38813/
Old Mar 18, 2013 | 02:24 AM
Cheap or not, dan, that's some nice work there. It's looks effective, well contoured for the application, and super strong. Good stuff.
Old Mar 18, 2013 | 02:25 AM
Lutz's Avatar
Nice work, Dan.
Old Mar 18, 2013 | 02:26 AM
go cytocis's Avatar
Nice work Dan; you probably saved ~$50 compared to some of the fancy CNC anodized case savers I have seen.
In the few instances I have seen chains come off, damage has ranged from nothing to catastrophic. I know it's pretty unpredictable to know what a broken chain is going to do once it's loose, but the common denominator in the instances I saw with no damage was the presence of a case saver. I wouldn't ride without one.
Old Mar 18, 2013 | 12:13 PM
mikesova's Avatar
What's the white thing you have stuck to the engine case? Looks kind of like the DRZ engine covers.
Old Mar 18, 2013 | 12:32 PM
That there is some nice work. What size front sprocket is that?
Old Mar 18, 2013 | 03:29 PM
drm's Avatar
drm
i like that sketch too!
EMS, it says 14T on his drawing.
Old Mar 19, 2013 | 12:02 AM
Thanks guys. We'll see how it works out. I'm thinking the leading edge of it will take a bit of a beating from the chain and whatever else gets drug in there.
The sprocket on the bike is a 14t.
Mike the thing on the stator cover is a guard I made up.https://www.kawasakiforums.com/forum...otector-39780/ Probably similar to the drz one you mention. One of my buddies has something like that on his KTM. The used stator cover I got off eBay to replace mine had a good gouge in it, so this will give me a little extra insurance.
Dan
Old Mar 19, 2013 | 03:37 PM
How much and when can we expect delivery.
