Carb question
Old Mar 28, 2017 | 12:49 AM
Kmcmjmtm's Avatar
Default Carb question
I took the carb apart and pulled the main jet to clean. While cleaning I noticed a small brass pice had fallen out. Near as I can tell I think it's part #16017 but not exactly sure. Does it go in before the jet and if so in which direction?
Thanks
Old Mar 28, 2017 | 01:53 AM
Klxster's Avatar
I assume you pulled the emulsion tube and the brass needle jet fell out,,? If so, it goes in only one way - when correct, it'll protrude into the carb bore a little bit..
Old Mar 28, 2017 | 02:23 AM
Kmcmjmtm's Avatar
Ok
Did some more reading and yes, I pulled the emulsion tube. Does that piece go in first over the slide needle and you say it protrudes into the carb bore when installed correctly?
I'll try that, I just wasn't sure where it came from.
Thx
jkd6h
Sep 6, 2012 01:03 PM
Arctra
Nov 21, 2010 11:48 AM
horizonod
Nov 15, 2008 12:38 PM
cokrkilr
Nov 22, 2006 03:28 AM
