Can a klx be lowered?
Old Jun 16, 2008 | 12:39 PM
neilaction's Avatar
Default RE: Can a klx be lowered?
ORIGINAL: JonnyD
Does adjusting the rear spring help with the hight? Or does that just allow for more cushion for weight? Also, how do i raise the front forks? Is it just a adjustment, or a part i have to buy? Thanks guys
Adjusting the rear spring, preload, will affect the height, but it also affects the rear suspension.
Adjusting the fork height is easy enough.
Just loosen the 3 bolts clamping the top section of each fork and slide the fork up.
But this affects geometry.
I raised my forks about 1/2 an inch.
Which was about as far as I could without the fork caps hitting the bars.
Then setting the rear preload to about 1/2 way seemed balance the geometry.
It worked "ok" and best of all it was free.
Old Jun 16, 2008 | 04:10 PM
JonnyD's Avatar
Guys thank you very much for your great responses. I'm going to get a link (3/4 inch), raise up the forks a bit, and reduce the rear shock about halfway probably. That is, when i finally get a klx [sm=badbadbad.gif]
Old Jun 17, 2008 | 05:51 AM
oldphart's Avatar
Banned
That's the fun about bikes. Get two riders identical size and weight change thefront or back 1/2 an inch one guy will love it the other will say it's impossible to ride.
Old Jun 18, 2008 | 07:18 AM
LDHunter's Avatar
I bought an used 2006 KLX-250S and it's been lowered with a lowering link and I'd prefer it to be at factory height. If someone want's to sell their original factory parts please send me a PM.
$bob$
Old Jun 18, 2008 | 09:07 AM
MaverickAus's Avatar
Neil let me know how it goes
Old Jun 18, 2008 | 01:55 PM
neilaction's Avatar
ORIGINAL: MaverickAus
Will do Maverick.
Bits due back tomorrow.
Hopefully I will get it back together for a ride this weekend.
Old Jun 19, 2008 | 01:34 PM
NL_KLX250's Avatar
I recently put Kouba Links on my 09. More for my wife than for me, but even I enjoy the lower seat height for now. We are both new to bikes to the added security of being able to touch easily helps to build confidence. I expect next summer the links will be coming off. By then the suspesion should be worked in good enough that touching should not be a problem. The dealer lowered the forks for my wife and reduced the preload on the rear so that it would sag more with her on it (dang featherweight hardly makes a dent in the seat LOL). I still find the bike handles nicely. From what I understand, you need to keep the front and rear in respect of each other so you're not upsetting the geometry too much, just lowering the COG really.
Have fun riding!
Old Jul 16, 2008 | 07:22 AM
  #28
LDHunter's Avatar
Here's mine....
You can clearly see the Kouba lowering link behind the foot peg.
It's for sale. PM me for details.
$bob$
fantom
Mar 25, 2013 09:34 PM
squidremz
Ninja 250R
Jul 8, 2008 05:42 PM
NL_KLX250
Jun 26, 2008 01:38 AM
Bad Bear
Oct 26, 2006 01:49 PM
gsims
Ninja 250R
May 23, 2006 08:22 PM
