As i have lowered my klx 250
Old Mar 24, 2013 | 03:32 PM
fantom's Avatar
Default As i have lowered my klx 250
The seat height of 89cm from the ground of my KLX for mè were a bit much,
after having pulled the fork legs, the situation has not changed much.
On the Internet I found the levers for single-and allow me to lower it to about 3 cm, but at a price that ranged from a minimum of $ 70
to a maximum of € 120.
The price seemed too much for two pieces of iron so I decided
to build on my own.
After doing some tests with a piece of iron to find the right fit I've made ​​of stainless steel thus solving the problem of rust.
In the first picture you can see the project in its initial phase.
Here in roughing using a hyper numerical control
This is the final result, the flow rate from 89cm to about 86cm.
Overview other equipment.
Please excuse my English
KAWASAKI KLX250
Old Mar 24, 2013 | 04:16 PM
Lotrat's Avatar
You are now the source for lowering/lifting links in Italy. Nice work.
Old Mar 24, 2013 | 04:37 PM
RimBender's Avatar
careful you don't bottom the tire into the fender because links lower but don't reduce travel
Old Mar 25, 2013 | 12:10 PM
fantom's Avatar
To avoid this, I increased the preload on the spring.
Old Mar 25, 2013 | 03:27 PM
MikeW's Avatar
I lowered mine 1 inch
but here you can buy them for $30 USD so pretty cheap to get
I also adjusted the forks 1 inch too so it sits level
I found after riding for a month or two I was hearing weird noises, found I needed to add preload to the shock too
I was bottoming out too much on that chain roller
Made a video
Old Mar 25, 2013 | 07:15 PM
fantom's Avatar
Thanks Mikew all information is welcome.
Old Mar 25, 2013 | 09:34 PM
Great job Phantom, I love it when people make their own stuff.
Dan
JonnyD
Jul 16, 2008 07:22 AM
NL_KLX250
Jun 26, 2008 01:38 AM
Bad Bear
Oct 26, 2006 01:49 PM
gsims
Ninja 250R
Oct 7, 2006 05:04 AM
gsims
Ninja 250R
May 23, 2006 08:22 PM
