Bridgestone TW41 and TW42
Old Aug 22, 2007 | 05:07 PM
fireroad's Avatar
Default Bridgestone TW41 and TW42
Anybody have experience with these tires? I think they are standard equipment on the DRZ-400S.
Old Aug 22, 2007 | 05:23 PM
Davebert's Avatar
Default RE: Bridgestone TW41 and TW42
I have a DRZ400S and I believe those are the tires. They are commonly referred to as "DeathWings" because some people have wiped out in wet grass or mud or loose soft sand. That said, I have 800 miles on my bike and I haven't wiped out yet (I probably shouldn't have said that...). I like the tires on the road and so far on hard pack fire roads etc they are fine. They are a bit squirrely in gravel and even more so in sand. I haven't road in any rain but have rode on wet roads after a rain and didn't notice any problems. I will run out to the workshop and verify the numbers for you so we are talking about the same tires.
Be right back,
db
Old Aug 22, 2007 | 05:31 PM
vfrpilot's Avatar
I have them on my XL600R. They do fine on the road and on hard dirt but really suck for traction in wet or muddy stuff.
Old Aug 22, 2007 | 05:34 PM
Davebert's Avatar
Just checked and they are the TW41 and TW42 tires I have. They corner quite nicely too
db
Old Aug 22, 2007 | 05:52 PM
fireroad's Avatar
Hmmm...squirely on gravel...that's my biggest complaint with the stockers...guess I'll spend the money on the tkc80's or the tw301/302. Thanks guys.
Old Aug 22, 2007 | 05:55 PM
FM_Thumper's Avatar
I had them on my Serow. Very hard compund. It looked like it would last 20,000 miles.
Old Aug 22, 2007 | 06:23 PM
fireroad's Avatar
Yeah, I'm not all that concerned about tire wear as I am loose gravel. I road a lot of trail in NM that had a lot of loose rock and gravel and the stockers were all over the place.
Old Aug 22, 2007 | 07:04 PM
FM_Thumper's Avatar
ORIGINAL: fireroad
Yeah if you want that controlled floating effect on loose gravel you want to go with something a lot softer and knobbier.
Old Aug 22, 2007 | 09:23 PM
HawaiiRider's Avatar
You might try some rim locks on the stock tires. Ijust did this so I could run the tires down to 10psi in the mud.I'll have a report after this weekend.
Nobrakes
Feb 11, 2008 02:49 AM
Arthas
Feb 9, 2008 12:03 AM
fireroad
Jul 13, 2007 01:27 PM
DeFran
15
Jun 5, 2007 12:32 PM
a16tony
Aug 2, 2006 08:02 AM
