Bike won't rev past 5k
Old Apr 13, 2010 | 06:41 PM
bmx_lar's Avatar
Cool Bike won't rev past 5k
i took it out of the garage today, wharmed it up, took it for a ride around the yard, and it tried to kill me. got to a spot where i needed to accelerate, and it bogged down like it was out of gas, and now it won't rev past 5k. plenty of gas, changed the petcock to reserve just because, and it still wont rev. pulled the plug and it shows its running rich. its bone stock with the exception of the dealer drilling out my pilot jet to 38. any quick ideas before i take it back and make 'em fix it under warranty? im kinda thinking that when they drilled the pilot out caused it to run to rich, and clogged the cat.
Old Apr 13, 2010 | 07:19 PM
ACOLE's Avatar
Everything clear in the air intake?????????????
Old Apr 13, 2010 | 08:12 PM
canklx's Avatar
Sounds like the dealer may have screwed something up when they drilled the jet. As it's on warranty I would take it back and have them fix it. That's what the warranty is for.
Old Apr 13, 2010 | 08:13 PM
adr's Avatar
adr
In addtion to the air intake, how about the Exhuast ? I had a mouse make a nice condo complex in my muffler before. Would start right up and run but wouldn't rev.
Old Apr 13, 2010 | 09:24 PM
bmx_lar's Avatar
intake is fine, i took the lid off and tried it, but it still bogged. as for the exhaust, im thinking clogged cat...who's bright idea was it to put a damn cat on a dirtbike anyways...thanks cailfornia
Old Apr 13, 2010 | 09:57 PM
LearjetMinako's Avatar
CA wasn't included with the KLX. The 06' & 07' models were only 49 or 48 state legal. The newer 09'+ have an evap system which now complies with CARB emissions.
Before you start jumping the gun with major problems. Start with the smaller stuff first. For starters, it could be the needle is stuck partly open or the fuel bowl float is out of spec. Try draining the fuel bowl first and try some carb cleaner additive.
Old Apr 13, 2010 | 10:06 PM
axel's Avatar
If you have the stock carb I would check the diaphragm for a hole or for an improper seal on the lip. If you don't have a CV carb anymore then check the basics mentioned in an earlier post.
Robert24
Jun 21, 2011 12:17 AM
PANGUI
Ninja ZX-7R
Sep 16, 2007 07:15 PM
teriyaki_rocket
Oct 10, 2006 10:04 AM
QuickstreeK
Ninja 500R
Jul 31, 2006 10:14 PM
hammerbyte
Jan 10, 2006 02:24 AM
