Bike dies after 7 miles, checked everything, need help....?????
Old May 30, 2016 | 12:46 PM
  #51
klxnoobie's Avatar
Congrats on the repair Werloc.
Old May 30, 2016 | 05:06 PM
  #52
Man...electrical gremlins...especially ignition/charging issues...nothing more fun. Werloc, on your coil test did you do the continuity/resistance tests in the manual or did you also get to do the "load" test on one of those devices that allows you to open an adjustable spark gap under battery power? Obviously almost no one personally has one of those, but most shops that have one will almost always test a coil for you. In some cases I've found it to be the only way to test a defective coil when the static continuity/resistance tests show OK...or swapping parts. Glad you figured it out. Your methods of diagnosis were logical and focused. Good job.
Old Jun 1, 2016 | 12:39 AM
  #53
Werloc's Avatar
TNC, I only did the static tests as per manual. The coil had no reading on the primary side, so I went out and found a used one cheap enough on ebay. When I got that, I did the same test and got the same results. Hmm, so I thought I'd just return that coil to seller for a refund. Then after a few more days not finding the issue with bike, I figured why not just try this coil I bought for the hell of it. Glad I did, because that was it. After looking more into that no reading I got, turns out, the test shown in manual is wrong. But since that coil sits in a hot spot, just above head, and right behind radiator, it just made sence to me to just try the new one. So really I can't take much credit, it was more just dumb luck....LOL Lord knows, I sure did put my time into going over every inch of every wire, and all electrical componants, and took apart every connection plug, cleaning, etc. I paid my dues.....lol And paid off, by accident.
Old Jun 1, 2016 | 12:06 PM
  #54
durielk's Avatar
The problem with testing, coils, condensors, circuit boards, is some fail when heated. When they are cool they have continuity (or not), and then when heated everything expands and something looses connections.
With other bikes u can could carry a spare plug in your pocket, pull the plug wire and test the system just after it dies. On these it would be very difficult to get at the plug wire.
Old Jun 1, 2016 | 01:48 PM
  #55
Bluezr7's Avatar
ah ha, I said coil or CDI in an earlier post. Great to hear that it is all fixed.
Old Jun 4, 2016 | 08:23 PM
  #56
jacksonriding7's Avatar
From: In North Western Jersey, but from Jackson, WY Originally
So good news, you've confirmed that all your connections are good and ready to go riding! congrats on catching the gremlin
Old Jun 5, 2016 | 04:56 AM
  #57
Werloc's Avatar
Thanks guys. Did 60ish miles today with no issues. Well, yesterday, its after midnight.
brycerichert
Jun 7, 2013 09:13 PM
Thefirstzukman
Mar 17, 2011 04:12 AM
matt62x
Sep 10, 2009 08:24 PM
aszrael1266
Sep 22, 2007 12:12 PM
