Big Bore reliability issues
Old Dec 4, 2006 | 06:31 AM
Rusty FJ's Avatar
Default Big Bore reliability issues
Does the Big bore kits cause reliability issues. i am refering to the 300cc kit that is taken from a KLX300's top end, if i am correct. I know it will cause reliabilty probs with sport quads but from what i understand the KLX engine is just a tapered down KLX300 engine. is this correct or am i hoplessly off track?
Old Dec 4, 2006 | 06:42 AM
klxstiffler's Avatar
Default RE: Big Bore reliability issues
installing the 300 cylinder and piston would be the exact same as having a out of the box klx300 so it's not a issue.
Old Dec 4, 2006 | 07:05 AM
mmatz's Avatar
ORIGINAL: klxstiffler
With Electric start.
Old Dec 4, 2006 | 07:56 AM
MaverickAus's Avatar
Seeing as the parts you use come from the Kawasaki factory and are the same parts used by the KLX300 I don't see why you would have any problems
[8D]
Cheers
Old Dec 4, 2006 | 04:22 PM
Marty's Avatar
I really do not see it as an issue, even one of reliabiltiy.
As was stated, they're genuine Kawasaki parts, unmodified. All you are doing is putting the 292 cc cylinder, piston, piston rings and piston pin onto a motor that is the same as the 292 cc displacement KLX300R. The downsizing was probably for emissions requirements.
I'm planning on going that route, Finger Mullet is already there. Nobrakes has already gone to the next level - 331 cc displacement.
Once Christmas is over, I intend to order the parts. Not sure at this time if it will be 292 or 331 that I'm going for. Probably 331 as there needs to be more than one big bore ***** here! [sm=burnout.gif]
Old Jan 4, 2007 | 01:54 AM
dmar's Avatar
What about the counter balancer they talk about for a smooth ride. Iam not a mechanic , but iam guessing it is the counter weight to the piston. Would the counter balancer have to be increased for a 300or a 331. I like the idea of a smoother and reliable ride.
Old Jan 4, 2007 | 02:54 AM
tremor38's Avatar
Changed:
The same counterbalancer, PN 130-0001,is used onboth the klx300 andklx 250. Riders with the 331 have reported increased vibration, though I'm not sure how much. I would guess that is due to the 331 kit not usinga stock Kawasaki piston.You might be able to get whoeverdoes the overbore to match the piston weights, if vibration isthat much of an issue.
ORIGINAL: dmar
Old Jan 4, 2007 | 03:31 AM
I can't say I've noticed an increase in vibration. I'm sure there's more, but it's not dramatic. Only time will tell w/regard to reliability.
Old Jan 4, 2007 | 01:00 PM
tremor38's Avatar
Hopefully the counterbalancer will help to offset that.
ORIGINAL: Nobrakes
Mr.P
ER 6N
14
Jun 23, 2013 01:44 PM
sw0ggd0gg
Jul 8, 2010 01:27 AM
mattyw
Oct 2, 2009 02:02 PM
punkenduro09
May 6, 2009 07:53 PM
maniac
May 26, 2007 12:36 PM
