Best way to remove countershaft sprocket?
Old Feb 17, 2017 | 01:35 PM
atleastbehandy's Avatar
Default impact-gun and a gear puller
After flattening the lock-washer, I used a 1/2" electric impact gun to spin off the nut. I did not need to lock-off the tire.
However, the sprocket itself was quite tenacious! I needed to use a small gear puller to remove the sprocket from the shaft.
Old Feb 18, 2017 | 04:43 AM
GBAUTO's Avatar
That's not good. Make sure that the splines are clean and free of dings-it should be a slip fit.
Old Feb 24, 2017 | 03:19 PM
reinigef's Avatar
I like the wood chisel idea, screwdriver and hammer kinda tears up the nut. Once away enough from nut hammering the socket to finish flattening is a great idea. I have a two foot breaker bar, kind of a long non ratcheting socket wrench. I have wife stand on rear brake lever while I stand on breaker bar and bounce...
Old Feb 24, 2017 | 05:04 PM
I use a small blade screwdriver to start bending the washer, then a really big tip blade screwdriver to bend the washer flat.
I also hold the brake and use a long breaker bar. Always torque it back on, probably will slather on some anti-seize next time too... you guys are scaring me.
I really liked Honda's method of using a splined retainer in a groove that held by using a 1/8 turn that would line up two bolt holes to bolt on the retainer in locked position. Clean and quick.
Old Feb 26, 2017 | 11:30 PM
Werloc's Avatar
Or, KTM only uses a snap ring with no bolt. Easy peasy.....
Old Mar 4, 2017 | 02:03 PM
s10gto's Avatar
My KDX is this way. Easy but does cause more spline wear. Ktm has now gone away from the clip.
greenmachine
Feb 9, 2010 02:24 AM
redpillar
Nov 2, 2008 05:03 AM
Bulls90
May 10, 2007 12:27 AM
jjm525
Ninja 500R
Oct 2, 2006 11:58 PM
