bent frame 2006 klx 250
Old Apr 2, 2013 | 04:28 PM
Tallmandr's Avatar
Default bent frame 2006 klx 250
So I have a 2006 klx 250 with a bent frame. is it possible to use a frame off a 2007 klx 300 are these frames interchangeable? its basically total out my bike or go this route.
Old Apr 2, 2013 | 09:24 PM
I'm relatively sure there will be tabs and other problematic areas between the two frames that will be different enough to cause some problems, but I doubt that any of them are insurmountable. I'd do it in a heartbeat and just juggle the parts and mods you might have to do to get the whole package to work to your satisfaction. Depend on what state you're in, you might have problems with the licensing of the bike because the 300 won't show as a manufactured-for-street-use model.
Old Apr 2, 2013 | 09:33 PM
Tallmandr's Avatar
I was going to have the frame re titled for my vin. I live in Colorado so I am pretty sure its possible. I am just worried the swing arm is long on the 300 and ill have to get a different chain or something.
Old Apr 2, 2013 | 10:09 PM
A new chain should be the least of your worries. Honestly, I think the old chain will fit, but even if it doesn't I'm sure it wouldn't hurt to put a new one on. Chains aren't free, but this will still be a cheap way to get back on two wheels.
I could see things like TNC mentioned giving you more trouble. You may have to fabricate some tabs here or there for mounting things like the gas tank, radiators, etc. It may all bolt right up, but, I think that is where the bike has changed more than anywhere. I would definitely say it's doable.
Dan
Old Apr 3, 2013 | 01:27 AM
RayCour's Avatar
What happened to get that condition? Tell us so we won't get this
Finger Mullet
Jun 12, 2018 01:41 PM
ms3man09
Feb 16, 2009 02:16 PM
stjoetalon
Apr 17, 2007 08:14 PM
parkedwreck
Aug 19, 2006 02:37 PM
Icantrideabike
Jul 22, 2006 10:15 AM
