BB 351, DJ 300, F/A screw, HMF can, CA smog delete
Old Mar 9, 2010 | 11:27 PM
Army the next up is the #38. I talked to Bill Sunday and he told me what he posted here,"Whatever your running now, go up one on pilot and two on main" I already have the #38 pilot in my carb after puttin on the slipon, so I guess I will try the #40 pilot and the #135 main. ?
Old Mar 9, 2010 | 11:28 PM
Right , not too expensive. I have done the same and bought more than the one I thought I needed.
Old Mar 9, 2010 | 11:31 PM
armycopter's Avatar
Dan, are you at sea level? I've got the 132 main in right now but I haven't verified it's the right one. Hopefully it is. I'll put the 38 or maybe jump right into the 40 on the pilot. I always thought that maybe I should have gone up one on the pilot prior to the 351 install so the 40 might be right on. I'll let you know.
Old Mar 9, 2010 | 11:48 PM
Rockford is at 750 ft.
I may order a 40 pilot and then a 132 135 138 mains. I want to look around on here and see what others are at before I order. I want extras so I can drop down when I take the bike to higher elevations out west.
I have to look and see what jets I already have, because I did order sizes over/under what I thought I needed when I put the FMF on. Definitely follow up with what works for you. Cousin Larry's set up should be similar to what would work for you.
Dan
Old Mar 10, 2010 | 02:49 AM
Keep in mind that the different companies number their jets a little differently. A Keihin 135 is different than a Dynojet 135. So raise your jet size according to the brand you already have.
Dan
Old Mar 15, 2010 | 11:49 PM
armycopter's Avatar
Ok, my bike seems to be running fine, lots of power, doesn't seem to have any flat spots (although I have not had it WOT yet as it's still breaking in), but I am getting some popping on decel. It had the popping when I ran the 35 (stock) pilot jet and it still has it with the 40 pilot jet. I've adjusted the A/F all the way up and all the way down but I keep getting popping. Any thoughts on this? It's driving me crazy.
I have new plugs over the smog stuff (carb and airbox) and they seem to be good. I also have the exhaust tightened down really well.
Any thoughts would be appreciated!
Old Mar 16, 2010 | 01:06 AM
CousinLarry's Avatar
I pop on decel too - mainly if I'm going down a hill and dragging the motor.. I've accepted it as I've tried a few different combos with the carb settings and nothing ever stopped it.
If you figure something out let me know. Mine's been like that since early 08 when I put the kit on with no probs if it makes any difference.
Old Mar 16, 2010 | 03:33 AM
  #28
b_joannblue's Avatar
Did you install the block off plate that was sent with your kit? This always stops the popping at low speed deceleration.
Bill
Old Mar 16, 2010 | 03:41 AM
  #29
Yes, I have the blocker plate on.
Old Mar 16, 2010 | 12:24 PM
  #30
armycopter's Avatar
Hi Bill, yes I have the block off plate installed. Do you think it could be leaking? I didn't use any sealant when I put it on.
Larry, it's not a bad pop but it's annoying...
