Basic stuff........
The UPS truck should be here any day now with my new chain and sprocket.
chain>>>>>>https://www.kawasakiforums.com/m_710..._1/key_/tm.htm
GREAT Write-up!!!!
Would anyone happen to havea good link about installing the sprocket.....any help would be appreciated............you veterans take all this easy stuff for granted, but us new guys find the simplest things very difficult.[&:]
Thanks-
Dave
GREAT Write-up!!!!
Thanks-
Dave
There is 6 bolts holding the sprocket on, they have allen key heads and from memory the nuts are 8mm. Put the correct allen key in the head of the bolt and with your 8mm spanner undo the nut off the bolt. Move to next bolt and repeat until all bolts are out. Remove the sprocket and put the new one on. Reassembly is reverse of removal, make sure you tighten the nuts onto the bolts, do not tighen the bolts into the nuts you will round out the heads.
P.S. you need to get a manual
Thanks KLX, I do have a manual and it says pretty much verbatim what you said.
And I fugured it was just that simple, I was just checking to see if there was some little useful nuggets of info from past errors.... or... I mean experiences that could be passed down.
Like---does a chain need to face acertain direction or like you said......tighten the nut to the allen screw not the screw into the nut! SEE- that makes senseand I would have done the last one, so these little tid bits to us newbies are very helpful and we can pass this knowledge down to others some day.
Thanks again
Dave
Thanks again
Dave
Quick note: a bit of "Loctite" on the nuts helps keep everything in place, just don't get the permanent kind!!
I use the medium strength, high temperature (so I can use it on the Muffler bolts as well...that way they don't fall out of your big gun muffler when your riding in Florida...
) locktite
http://rshughes.com/products/079340_29513.html
hope thathelps...
) locktite http://rshughes.com/products/079340_29513.html
hope thathelps...
ORIGINAL: double d6
Thanks again
Dave
Thanks again
Dave
gotrice
17
Jul 31, 2006 05:01 PM
Jutboy
Mar 26, 2006 03:13 AM
