Aus spec carb slide has 5 holes!
Old Jun 8, 2008 | 05:31 AM
The Mekon's Avatar
Default RE: Aus spec carb slide has 5 holes!
NoelKLX said "Icurrently have a 13/35T sprocket mix on the bike but want to replace the 13T with a 14T to give me a more comfortable cruising speed"
- Are you talking about a KLX250 or 300?? The standard rear sprocket is a 42. A 35 would be a midget and the bike to high geared.It would beincapapable of pulling top gear.
If you mean 45, then 14 would give higher top speed. a 15/45 would revert to standard gearing.
Contrary to everything that appears in this forum, lowering the gearing does not give the bike any more torque.
In trail riding it is matter of compromise. On my modified 250/300, I run 13/47. I find that I need a fairly low 2nd gear if I am to make slippery hill climbs OK. 1st is too low and can cause wheelspin. Any hill that requires some momentum is best taken in 2nd gear. I save the low 1st gear for very tight and slow stuff.
The bike is hopeless on the highway, but I trailer it to my ride spots.
Old Jun 9, 2008 | 11:30 AM
NoelKLX's Avatar
ORIGINAL: The Mekon
Sorry Mekon and others. Your are right the bike is in fact a 14/42T sprocket mix. Don't know how I got it so wrong - trying to count the cogs in a badly light shed, I guess. What if I stayed with a 14T front and used a 39 (or 38T) rear sprocket. Would I get away with an even smaller rear sprocket? Remember I am hoping to get 2+hp extra out of the bike after the carbie, rejetting, breathing and exhaust mods.
Noel
Old Feb 6, 2010 | 06:45 AM
Blueraven's Avatar
could someone please re post the pic of the aussie carb slide or the pdf?
about to pull the carb apart myself and just want to see the aussie slide and which holes i specifically need to fill...
Thanks...
Old Feb 6, 2010 | 09:08 AM
WestOzKLX's Avatar
These three in the front of the slide.
Drill the hole (7/64") next to the one the needle exits from.
Old Feb 6, 2010 | 10:22 AM
Blueraven's Avatar
Awesome thanks...
Just bought my 06 klx250 on the weekend and and juicing her up as soon as possible.
(got stuck trying to fit the 13t sprocket...sigh mine must have been been put on by a team of ninja or something.)
Old Feb 6, 2010 | 10:27 AM
neilaction's Avatar
Haha They're all pretty tough.
Welcome to KF.
jimmy101
Jun 30, 2011 10:14 AM
horizonod
Dec 14, 2008 01:21 AM
ScoticusMaximus
May 22, 2008 01:46 AM
WestOzKLX
Apr 27, 2008 03:23 AM
NavKLX
May 22, 2006 09:24 AM
