AUS KLX250S Converted to SM with 17" want to Upgrade Brakes to 320mm
Old Sep 21, 2009 | 06:11 AM
MotoFan's Avatar
Default AUS KLX250S Converted to SM with 17" want to Upgrade Brakes to 320mm
Hello,
Has anybody upgraded the brakes on the 2009 KLX250S/SF to use 320mm Brakes and Caliper.
I was hoping if they had what they used and what part numbers, etc
Looking to get
320mm Disk Rotor, Caliper, Stainless Steel Lines
and potentially a brake cylinder
Cheers
D.
Old Sep 21, 2009 | 04:41 PM
testify4's Avatar
I was considering a supermoto conversion for my 2007, but now I am leaning toward a 2009 KLX SF or a 2009 DR-Z SM due to the cost of the wheels, suspension changes and brake conversions.
I think this is the popular kit that some supermoto converts here have used:
http://www.motostrano.com/ebcsuovdico.html
Old Sep 21, 2009 | 08:10 PM
Newblud1775's Avatar
Motofan, I was planning to do the same thing. Searching the forum here, it looks like the front rotor for a KLX 300 will work, you just have to make the mounting holes a bit larger, maybe with a drill press or a hand drill, if you're good like that. The EBC Supermoto Brake Kit, that testify4 linked to, comes with the caliper relocation bracket you'll need in order to adjust for the oversize rotor. I've found the kit at a few other sites and maybe a few bucks cheaper than motostrano.
EBC P/N: SM6015C
http://www.mawonline.com/google/P17110565.HTM
http://pcsupermoto.com/cart2/index.p...products_id=57
daren1093251
Jan 21, 2014 05:24 PM
cpr1
May 30, 2011 04:44 PM
work
Feb 6, 2011 02:06 PM
zzrotceh
ZZR 600
Feb 1, 2011 06:23 PM
davehayward1
Sep 20, 2010 07:28 AM
