Anyone see this in person........
Old Nov 9, 2007 | 12:52 PM
double d6's Avatar
Default Anyone see this in person........
Has anyone seen this in person? How does it look/fit on our bike?
http://www.motorcycle-superstore.com...Headlight.aspx
Looks ok and Priced right.
What do ya think?
Dave
Old Nov 9, 2007 | 01:12 PM
Default RE: Anyone see this in person........
i like the stock one better...... not big on the gaps in the plastic on that one....
Old Nov 9, 2007 | 01:16 PM
Iowaguy.'s Avatar
what's wrong with the stock one? put in a brighter bulb if it isn't bright enough. that ufo stuff is fugly imo and anything that resembles it like this one. I'm with Eric on this one. the oem unit looks like it belongs.
Old Nov 9, 2007 | 01:21 PM
double d6's Avatar
https://www.kawasakiforums.com/m_219150/tm.htm
Don't know why I didn't add it in that thread!!
I smashed the stock one.......New plastic costs as much as this whole assembly.
Can't ride without replacing it..........the whole front is all crooked..throwing off my balance.
Old Nov 9, 2007 | 01:56 PM
Iowaguy.'s Avatar
aaah, I see. have you looked into baja designs? they may have something not as futuristic looking as that acerbis or ufo. I just don't like those lights for some reason. I guess on the bike they may not be bad. I'm just a stock kind of guy I guess. I hate the white shroud on the '07, it's worse than the ufo stuff. The green '06 is the nicest in my book.
Old Nov 9, 2007 | 01:58 PM
Old Nov 9, 2007 | 02:09 PM
double d6's Avatar
I have the shroud off and all the metal guts are bent real bad..........Do these after market headlight assemblies go over all that junk?
Can I use my 55w bulb with any of the aftermarkets?
This really sucks man.............................
Old Nov 9, 2007 | 10:38 PM
redbrd's Avatar
Dave after my bike came off the trailer the plastic shroud was smashed but the gut;s are not bad,
if you wont the brackets let me know i am sure we can work something out.
Old Nov 10, 2007 | 05:12 AM
MaverickAus's Avatar
ORIGINAL: double d6
You take off all the metal junk and replace it with a nice lightweight headlight unit that straps to the forks with rubber bands. If you look at the pic of the headlight I showed you in the other forum about your headlight you will see the rubber bands. Once again if you don't use the light much it's ideal. The aftermarket ones are not as bright as the stock due to a lower rated bulband it may be the case the aim may not be perfect. Mine does have an adjusting screw for headlight aim but mine is a genuine Kawasaki unit. I don't think you can use the 55w in the aftermarket ones I think it would be to hot and melt / damage the plastic.
Cheers
[8D]
Old Nov 10, 2007 | 12:37 PM
green242's Avatar
But if you take off all that "metal Junk" from the front to mount to the forks, then that gets rid of the speedo does it not? Unless you do a bunch of cutting of the bracket.
Anyone got one of those brackets lying around I could have? Or buy?
rocketrotary
Nov 4, 2007 01:47 PM
dr_claw
Apr 13, 2007 08:30 AM
Mordeth
Aug 30, 2006 03:53 AM
600nonR
May 24, 2006 06:36 PM
600nonR
May 19, 2006 10:15 PM
