Any "issues" with a 50T rear sprocket?
Old Jul 3, 2014 | 11:49 PM
Originally Posted by Oldad
I checked the fit of the rear chain guide and the chain guard last night against my current 47T rear sprocket. It was a tight fit in both cases. It appears that the chain guide would have to be modified, as you've done, and I'm wondering, will the chain guard have to come off? There seems to be less than 1/4 inch clearance with my 47 now.
I wish I could remember exactly what I did with the Hot Foot Moto guide and my old aluminum guide plates, but it's been quite some time. I combined the old guide plates and the composite guide unit in a way that moved the unit a little more forward and angled the guide block to accept the chain better from the lower angle. It's worked great with no issue or oddball wear. I kind of like using the old aluminum guide plates as they have also given some additional protection to my HFM guide.
Old Jul 4, 2014 | 05:43 AM
Thad, how about some good pictures of it? Something about a thousand words. My aluminum guide went crunch on rocks.
Old Jul 4, 2014 | 06:42 AM
Richard Avatar's Avatar
Thanks for the input. This just the kind of information I was looking for. Your type of riding sounds just like what I prefer.
I'll take a look at the chain guide business to see what I might need to do. I bought my '06 used with the 47 already installed, so if I had a problem with the guide I didn't know it.
I checked out the hot foot stuff too, but if I understood you correctly, you had to modify your rear guide anyway, even with the hot foot.
I threw a 48T on my almost a year ago, - before I knew it may not work out, but it went on and is being used without modifying the chain guide. I don't think a 49T or larger would clear tho..
cpr1
May 30, 2011 04:47 PM
cpr1
May 30, 2011 04:44 PM
work
Feb 6, 2011 02:06 PM
zzrotceh
ZZR 600
Feb 1, 2011 06:23 PM
davehayward1
Sep 20, 2010 07:28 AM
