For all of those interested in upgrading suspension
Old Oct 26, 2007 | 03:46 PM
AgoosSS's Avatar
Default RE: For all of those interested in upgrading suspension
Jerry at FSW does all of my major work on my KLX300including my suspension. A completesuspension jobisa night and day difference over stock and IMO may be the best upgrade for the KLX.It's the first thing I would do if I had a new KLX, even before power upgrades. The big advantage of the KX forks is you will have both compression and rebound adjustments. I have talked to Jerry about the swap and at this point he seems to think it won't be a huge difference over my re-worked fronts. If I was starting from stock I would maybe pursue the swap a little more.
Old Oct 26, 2007 | 06:00 PM
britboard's Avatar
I've done this conversion using a 93kx 250 front end, and it makes a big difference to the ride quality and off-road wash-out. if you take the complete front end it will fit fine but you will need to spin down and re-thread the headstock shaft at the top to allow the 25mm bearing from the klx to fit as the kx uses a 30mm, not a big job if you have access to a lathe. well worth the effort in my opinion for my 93 klxr, but mine did come with traditional forks to start with and having never ridden a more modern klx with upside downies i cant make a complete comparison.
Simon L
[IMG]local://upfiles/4476/932F727169E24BC4A76F2CB39EA55B2C.jpg[/IMG]
2k1w=no$
Jan 7, 2009 12:02 AM
jayden
Ninja 250R
Apr 15, 2007 06:19 PM
Marty
Aug 27, 2006 08:09 PM
goodfella_480
KLR250
Jul 24, 2006 12:21 AM
goodfella_480
Apr 13, 2006 07:54 PM
