Aftermarket Petcock
Old Jan 18, 2017 | 04:41 PM
ramsey.mangus's Avatar
Default Aftermarket Petcock
Mine, on my 06 klx250s, doesn't stop fuel flow when turned "Off", so I have to drain the carb each time I cold start er! At least I think that's the problem.. Old fuel in the carb.. Keep in mind I'm starting it in sub zero temperatures (-10 /-20) but with effort she fires up.. after draining.. which is a tedious process..
Where can I get a good aftermarket one? or even OEM if it comes cheap..
Old Jan 18, 2017 | 05:37 PM
Brrrr.
Is a rebuild kit available?
Old Jan 18, 2017 | 06:30 PM
Originally Posted by IDRIDR
Brrrr.
From what I've seen, the petcock on the 1st Gen klx250s isn't like your conventional petcock, so I don't know if a repair kit like that would work still?
Old Jan 18, 2017 | 09:06 PM
I don't know. Mine is attached to my stock fuel tank buried away someplace in the garage.
Old Jan 18, 2017 | 09:46 PM
You can get parts. Look here. Refresh the window if it doesn't show the diagram, may take a couple times. Parts are 43049-1091 and 92055-1419.
Old Jan 20, 2017 | 12:11 AM
that helps, thanks.
Old Jan 20, 2017 | 09:45 PM
No problem. Glad to help.
stickman2332
Jul 3, 2008 12:27 AM
car5car
Nov 15, 2007 10:18 AM
Moe Szyslak
Jul 16, 2007 06:09 PM
cwgoff
Feb 21, 2007 04:28 PM
Moe Szyslak
Jan 21, 2007 03:24 AM
