Advice on electrics for the KLX.
Old Jul 31, 2009 | 06:24 AM
neilaction's Avatar
Is it that simple?
If I trace the common earth from the H4 globe back some, (I assume there are three wires into the globe, 1 live for low, 1 live for high, and the common earth,) then cut the wire and install a simple switch inline, I'll get the desired effect. The ability the turn off both low and high beam at will. Gives me the option to start the bike without the lights running when the switch is in the off position.
Yep, its that simple.
Old Jul 31, 2009 | 06:27 AM
WestOzKLX's Avatar
Sweet. I'm off the 12 volt shop right now. one waterproof switch coming my way.
Old Jul 31, 2009 | 06:30 AM
neilaction's Avatar
I over complicated the latch circuit a bit.
If you use the earth return from the headlight as the switching point, then this will do it.
Old Jul 31, 2009 | 08:52 AM
slippery750's Avatar
+1 ...........Nope, this is how I would do it. No new holes to drill with an unsightly switch mounted in already limited space. Making a current switch do double duty is great!
Old Jul 31, 2009 | 02:57 PM
roadglider's Avatar
Nice thing is these bikes are really easy to push start LOL. neilaction looks like you have a real good understanding of electronics. I like how you Aussies are such well grounded and down to earth folks.
Old Jul 31, 2009 | 03:04 PM
neilaction's Avatar
Old school electronics
Nothing post 1985 if you don't mind.
Old Jul 31, 2009 | 03:54 PM
No offense roadglider but when most people see a wiring diagram they run for the hills! Once you understand what the symbols are for in the diagrams and the basics of what a diode, resistor, relay, latching relay and a couple of others things do you got it made!
Old Jul 31, 2009 | 04:16 PM
roadglider's Avatar
I know a little about electronics. I know the symbols for a diode (switch, ground, cap, inductor, etc..) and that it passes current on the forward bias and won't on the reverse bias. I just thought it was a clever and simple way to do it, and I'm into really bad puns.
Old Jul 31, 2009 | 04:52 PM
Someday when I'm not so broke, I am going to install the kick starter. I often ride down roads only to end up at the bottom, then its off to explore on foot. There is no push starting the bike in that situation. for $300. I want to add that option back in. I did the install on the wife's 2006 XT 225, and it was a piece of cake. Here is the link to that job. I did this right after my......uhhhhh.....man surgery. LOL
https://www.kawasakiforums.com/forum...ight=vasectomy
And here is a good writeup from Finger on our bikes.
https://www.kawasakiforums.com/forum...+Start+install
Old Aug 1, 2009 | 02:11 AM
MaverickAus's Avatar
Have you ever tried to push start a KLX250? Mine is a pig to push start just locks the back wheel almost every time even in second gear. Never had the electric start let me down yet.
Neil's idea is a good one though if you want the light off to start with.
