Acerbis Tank Bracket
Old Nov 5, 2014 | 11:49 PM
ol'klx-er's Avatar
There is a threadlocker that's even "lighter" than the blue.
From the tube: "Threadlocker Green Penetrating Grade".
I use it when I'm building bicycle wheels. Gives just that extra bit of hold. It's intended for use post assembly but works fine pre-assembly as well.
Old Nov 6, 2014 | 12:30 PM
dpippin's Avatar
You might want to try
Loctite 222MS Threadlocker is a low strength product designed for small fasteners to 1/4 inch
Great for small bolts and nuts that may have a problem releasing when disassembling.
Doug
Old Nov 10, 2014 | 11:53 PM
CraigT's Avatar
I didn't have a vice so I put a 90 bend in the straight piece as best I could with a hammer. Then I put the twist in it to get around the radiator hose. OK for now but I will have to redo it to push the shroud out a hair more where it can potentially rub against the radiator.
Old Nov 12, 2014 | 02:52 PM
Oldad's Avatar
Default Bicycle Wheel Locktite?
Where on a bicycle wheel do you use Locktite?
Old Nov 12, 2014 | 03:40 PM
ol'klx-er's Avatar
The spoke nipples/spokes interface.
speed2101
May 20, 2006 04:13 AM
jiminwaseca
May 11, 2006 07:11 PM
Marty
May 1, 2006 11:50 PM
bmwhd
Feb 25, 2006 12:28 AM
DJFields
Jan 7, 2006 04:04 AM
