About Air fuel mixture on klx/Dtracker
Old Apr 28, 2021 | 05:27 PM
Nandun.A's Avatar
Default About Air fuel mixture on klx/Dtracker
Dtracker250(2007)
Recently i have cleaned my carburetor
and i forgot how many turns to do on A/f screw
can u guys help me to turn that air fuel mixture screw (Sry for my bad english)
((Everything is stock except the exhuast))
Old May 3, 2021 | 08:37 PM
GBAUTO's Avatar
I'd say 2-2 1/2 turns out from seated should get you in the ballpark.
Old Jun 27, 2021 | 02:27 PM
Nandun.A's Avatar
thank u
Old Jun 27, 2021 | 03:44 PM
durielk's Avatar
Isn't the A/F screw a final adj made to the bike?
IMO, it needs to be adj to how the bike is running, not some majic number.
Old Jun 27, 2021 | 09:53 PM
Klxster's Avatar
If the fuel screw is not damaged, and the fuel screw seat is not damaged, 2.5 turns out is where you start.
If any of the above ARE damaged from overtightening the screw closed, then fewer turns out will be the "norm"..
All you need to do is set idle to 1250-1300 rpm, and use the screw to achieve the best idle possible. If using a #38 or #40 pilot jet, you set the screw to midway between idle drops.
horror_fan
May 3, 2018 06:33 PM
Brieninsac
May 21, 2013 07:49 PM
Brieninsac
Mar 6, 2012 04:00 AM
smjm
Feb 13, 2010 02:09 PM
markturbo
Feb 25, 2008 12:18 PM
