7500mile prep work
Old Oct 31, 2006 | 04:15 PM
a16tony's Avatar
Default 7500mile prep work
I'm getting ready for my 7500miles check up this weekend. What has been the weak spot on the KARC? How much valve wear should be expected? I hope they are in spec, I set them at the loose end of the scale. And for those interested, I have ordered a new stock countershaft sprocket. With 6100miles on it, it looks terrible. I had to change the DID chain last weekend with 6700miles on it, very worn. Please let me know if there are issues that you have come across that I should look at.
Old Oct 31, 2006 | 04:21 PM
Default RE: 7500mile prep work
Hey Tony - if I were you I'd go ahead and replace the rear sprocket as well. The chain, front, and rear sprockets tend to wear together and all will last longer if replaced together.
Old Oct 31, 2006 | 05:22 PM
You might take the steering apart and check out those bearings. That is if you washed it every week during the summer like I did.
Old Oct 31, 2006 | 06:01 PM
a16tony's Avatar
+1, in process.[sm=smiley20.gif]
Old Oct 31, 2006 | 06:03 PM
a16tony's Avatar
ORIGINAL: deej
+1, done, used marine grease
maninthesea
Mar 2, 2010 04:59 AM
Phil2801
Ninja 250R
16
Nov 6, 2007 09:30 PM
lefecious
Apr 15, 2007 05:21 AM
tremor38
Nov 28, 2006 02:19 PM
bryantjt
Sep 13, 2006 02:04 AM
