351 burning oil
Old Dec 10, 2017 | 11:16 PM
  #91
canklx's Avatar
Originally Posted by b_joannblue
Hello All,
Regarding the oil consumption & incorrect ring size.
I've sent a customer's 351 cylinder, piston, and rings to JE Piston to be analyzed as to what they feel the problem is. I hope to hear back from them this coming week & will post the results as soon as I get them.
As far as incorrect ring size, all rings are fit to the cylinder before I ship them.
Bill
Any update on what JE discovered in their analysis?
Old Dec 11, 2017 | 02:17 PM
  #92
sphen's Avatar
I have about 100 miles on the rebuild and so far everything is going well.
One thing i cant figure out: the first kit i installed (with upgrade to Bills mikuni carb), the cold starting improved dramatically - no need to choke just a few twists of the throttle to "prime" it, and it would start up instantly and settle into idle quickly. for some reason when i installed kit #2, its back to being cold blooded like it was with the stock carb and bore. choke, fight with it, start, then warm up for several minutes before idle stabilises and can unchoke.
Old Dec 11, 2017 | 02:19 PM
  #93
durielk's Avatar
It's winter now?????
Old Dec 11, 2017 | 02:26 PM
  #94
sphen's Avatar
welll....not so much down here in the south.
only thing i can think of is check my timing yet again just for sanity
Old Dec 12, 2017 | 09:59 PM
  #95
RaceGass's Avatar
Vacuum leak? Check hose clamps n spray wd40 around intake areas?
you sound very thorough!
Old Dec 13, 2017 | 01:17 AM
  #96
sphen's Avatar
since you mention it - I do always have trouble getting the intake boot on all way around and seated well. I’ll check that again.
What is this wd40 trick you speak of? Spray around the hose clamps and see if it gets drawn in?
Old Dec 13, 2017 | 01:49 AM
  #97
RaceGass's Avatar
yes it helps to identify if there's a leak. Exactly where the rubber intake contacts the carb
Old Jan 4, 2018 | 02:51 PM
  #98
canklx's Avatar
"Originally Posted by b_joannblue
Hello All,
Bill"
Bill, Did you get any results from JE Piston yet?
Old Jan 5, 2018 | 07:43 PM
  #99
RaceGass's Avatar
Specification sheet for big bore JE piston kit.
Thank you B&B Cycle the kit I received is running stronger than ever
Old Jan 8, 2018 | 10:00 PM
  #100
Landon's Avatar
So I'm torqueing the head back on this morning. Got to the last of the pair of smaller side bolts, and I notice it won't torque up, then I feel a burr, then I take a photo and see this
https://www.dropbox.com/s/of8dl9sa9u...%20AM.jpg?dl=0
arrrggghhh. Is there a fix or am I in line for a new $$$$ylinder head!?!
Sphen
What did you end up doing to remedy this? I did the same thing, makes me think the torque value listed in the manual maybe wrong.
