340 Results!
Old Jul 16, 2007 | 01:47 PM
kgwld1's Avatar
Default RE: 340 Results!
Thanks, I'm pretty sure it a lean needle postion but why bother dail it in when I'm waiting for the pipe and now a gas tank!
Kevin
Old Jul 21, 2007 | 05:06 PM
chainslack's Avatar
Plumbing.........your bore sizeis up 36%
I ran 4 into 4 oem pipes on an old 75z1 after I set it up with a 1200cc big bore kit. The carbs were already jetted for a 1013 kit & oem air box. Well, of course it didn't make any great power but I was just trying to put a quick 5 or 10 minutes on the new set-up.let it cool, check tourqe & all that. I switched out the pipes & put a big bore denco tricone header system on & returned to the backroads to buzz it for another session. It was like my cr500 with a passenger & I still had to fine tune it for idle to top end.
Steve
Old Jul 24, 2007 | 07:23 PM
kgwld1's Avatar
Default RE:UPDATE: 340 Results!
Well just got my tank and put it on the bike! The bike fired right up, so I said here we go the jetting in the 36mm is pretty darn close, I'm still running the stock pipe so I can feel it choke off a bit due to that but I'll wait for my new fmf pipe (and if it is still backordered all just build my own header). The bike lofts the front end up in the bottom 3 gears no problem. It pulls clean thru the rev range. I"m leaving for my other home on Thurs. so when I return I'll let you know how it goes.
I'm so glad I did the 340 with the pumper it's not even the same bike now.\
Kevin
Old Jul 25, 2007 | 05:08 PM
kgwld1's Avatar
Default RE: RE:UPDATE: 340 Results!
Just went for a 40 min. ride the bike pulls smoothly and pulls without a hiccup! I'll see what see does in the sand!
FrankKLX250s
Sep 4, 2007 09:45 AM
kgwld1
Aug 1, 2007 10:36 PM
kgwld1
Jul 16, 2007 03:00 PM
mustang
May 11, 2007 12:35 PM
mustang
Mar 25, 2007 06:04 AM
