29°F this morning and the KLX started flawlessly
Old Nov 10, 2007 | 01:29 PM
vtgreen's Avatar
Default 29°F this morning and the KLX started flawlessly
just thought you all might like to know
Old Nov 10, 2007 | 02:23 PM
Default RE: 29°F this morning and the KLX started flawlessly
Its not temperature sensative, its how long it sits... how long has it sat since last running? Went to start mine up yesterday and wouldnt start, drained the carb bowl and fired right up. Hell mine fired right up at 10 degrees last winter.
Old Nov 10, 2007 | 03:05 PM
jaylaudeman's Avatar
Mine seems like it is harder to start up in the colder weather. I usually turn off the fuel switch about a min. before I get home on the road to try to use it all up, but it still seems to want to start harder in the cold if its sat for like 2 days or more. I can get it to start right up in wamer weather like 50 or higher, so I didn't really think it would be the valves yet or would it??
Old Nov 10, 2007 | 03:08 PM
vtgreen's Avatar
it's been sitting outside untouched for almost 3 weeks. I was surprised it started at all!
bryantjt's Avatar
Even with properly shimmed valves its very finnicky if it has sat for more than a few days. You can tip the bike sideways to get the float to open up and get fresh fuel in the bowl and that usually works. Or I just turn off the fuel and make 2 laps around the yard and it usually dies pulling into the garage. Mind you I only do this in the early spring and late fall when the weather is pretty crummy for riding anyway.
Old Nov 10, 2007 | 03:11 PM
jeffzx9's Avatar
Crummy weather makes you a better rider, though!
Old Nov 10, 2007 | 03:59 PM
Heck, that was a morning ritual for the Husky 500 or for the CR 480!
Old Nov 10, 2007 | 09:06 PM
MaverickAus's Avatar
With the Mikuni carb mine fires up first time every time ..... unlike the CVK
Old Nov 10, 2007 | 09:09 PM
kawi750r's Avatar
mine's alway started up right away, even after sitting for 3 weeks or so when i can't get into town to ride it. it does take a while to warm up and idle well tho.
deej
Dec 30, 2013 01:16 AM
rgoers
Aug 28, 2012 06:36 PM
jhoffy22
Jun 17, 2011 03:10 PM
Odimus
Joke section!
Aug 30, 2009 06:42 AM
boaradin
Apr 10, 2008 10:22 PM
