2010 KLX250SF won't shift into 6th
Old May 12, 2018 | 10:54 PM
Dakjos's Avatar
Default 2010 KLX250SF won't shift into 6th
Deer jumped out in front of me and I laid the bike down (left side) going about 50mph while in 6th gear. I just put everything back together today and I noticed the bike won't shift into 6th now.
The first 5 gears are fine and smooth, on the 6th the lever moves up and I can't feel anything there, it just moves up and back down and obviously doesn't catch a gear.
Anyone have any thoughts on what it could be or how to proceed?
Old May 13, 2018 | 01:39 AM
GBAUTO's Avatar
Sorry to hear about your luck...I can relate.
Chances are when it went down it transferred quite a bit of force through the shifter. There's a sticky about shift star that describes the pin that usually gets bent. Good news is that it's easy to fix.
Old May 13, 2018 | 04:03 AM
Dakjos's Avatar
Hey, yeah I saw this thread, which I'm assuming is the one you're referencing. https://www.kawasakiforums.com/forum...ar-gone-34237/
Does anyone know the part name? I'm looking on bikebandit right now and I can't seem to find that part in their blow up schematic...
Old May 13, 2018 | 01:53 PM
GBAUTO's Avatar
https://www.bikebandit.com/oem-parts/detail/kawasaki/92150-1803/b873261?m=154174&sch=731325
Listed under crankcase parts-it's the return pin for the shifter pawl. That's what usually gets bent. You will need to disassemble the cover plate and look for signs of damage to verify.
Old May 13, 2018 | 06:24 PM
Dakjos's Avatar
https://www.bikebandit.com/oem-parts...174&sch=731325
So I tore off that cover (man that thing did not want to wiggle out of there) and it turns out that pin is bent and the shift star is missing a peg. But oh well, easy fix! Very thankful it wasn't anything worse.
Thanks GBAUTO, you've been a great help!
punkenduro09
Dec 8, 2014 08:28 AM
Bayou220
Feb 26, 2014 12:08 AM
gunguy
Apr 21, 2011 02:50 PM
Thunderchild
Jan 9, 2007 05:55 AM
skweekie
Aug 2, 2006 09:38 AM
