2009 valves
Old Aug 17, 2010 | 05:51 PM
bweekley's Avatar
Default 2009 valves
I'm wanting to learn to do things for myself on this bike (09250sf) so I'm learning as I go. I've adjusted valves on vw motors but that is about it. so can anyone point me in the right direction for checking and adjusting valves on these bikes, what tools are needed, how do you start.
Thanks in advance for the help.
Old Aug 17, 2010 | 05:57 PM
TomN's Avatar
I need to do my valves too!
Old Aug 17, 2010 | 06:22 PM
roadglider's Avatar
Get (download from this site) the shop manual and read up on it. It's really very easy all you need is a set of feeler gauges. Remove the valve cover on the top of the engine and the inspection plug (to find TDC on the engine left side). Place the engine at TDC on the compression stroke and insert the feeler gauge between the cam loeb in the shim. The procedure maybe in the owners maual as well I'm not sure.
Old Aug 17, 2010 | 07:50 PM
roadglider's Avatar
I meant "cam lobe and the shim". Sorry.
Old Aug 17, 2010 | 08:17 PM
Blackheart58's Avatar
Isn't that the name of a band? "Cam Lobe and the Shim"
Old Aug 18, 2010 | 02:58 PM
Highbeam's Avatar
Don't forget that you ought to replace the valve cover gasket as the OEM one has been known to be a leaker. The real tough part is when you find that the valve clearance is out of spec.
Old Aug 19, 2010 | 01:38 AM
ol'klx-er's Avatar
Measuring the valve gap is fairly easy. Actually adjusting them is quite involved; the camshafts have to be removed to get to the shims under the buckets. And you need a selection of shims to get the right setting. Nowhere near as easy as the VW's screw with locknut arrangement.
mtnmac
Apr 17, 2014 10:58 PM
thecount
Jun 9, 2006 08:42 AM
M1A1
Apr 17, 2006 07:07 AM
quiklilrex
Aug 22, 2005 10:10 PM
ntence
May 24, 2005 12:33 AM
