2009 Handguards
Old Apr 18, 2008 | 02:26 AM
SherpaDude's Avatar
Default 2009 Handguards
Has anyone installed hanguards on their '09 yet?
I know there are many possibilities for the '06-07 bike, but does that change for '09? Any recommendations? Thanks!
Jeff
Old Apr 18, 2008 | 03:36 AM
35racer2's Avatar
Default RE: 2009 Handguards
I just put the Rally Pro's from Acerbis on.
The throttle side is easy.
The clutch side, not so much.
The front "bracket" for the guard goes right where the brake line and the clutch cable meet, so it's a bit tight.
In the end, I ended up moving the upper round clip that is around the brake line...the one that is held on by the upper triple tree bolts. I moved it down so that only one bolt is holding the clip on.
I also put a piece of hard, smooth plastic in front of the guard, so the brake line rubs against that... so it won't wear out. So far, it's working perfect.
I'll take a photo tomorrow if anyone needs it....
Old Apr 18, 2008 | 03:39 AM
SherpaDude's Avatar
ORIGINAL: 35racer2
Thanks for the recommendation and the write-up. Photos definitely appreciated, not only for fit, finish and functionality, but for looks! Is there a link to where you bought these and a price? Thanks!
ORIGINAL: Coast Mountain Guy
As far as handguards go, I had the dealer fit a pair of Cycras on for me. Apparently they went on with minimal effort. They swapped out the bar clamps, though, because the guards came in a set that included clamps for "oversized" aftermarket bars. And you can order the plastics in a bunch of different colours, shapes, etc.
Any photos of these? Thanks!
Does anyone else have any recommendations for the '09, and photos?
Jeff
Old Apr 22, 2008 | 04:51 PM
SherpaDude's Avatar
I ordered the U-mount Cycras straight from the factory this morning. Anyone know the difference between the U-mount and the triple-clamp mount? The salesperson on the other end recommended the U-mount.
U-Mount
http://store.cycraracing.com/prrapawiuclh.html
Triple-Clamp
http://store.cycraracing.com/trclmopr.html
Cheers,
Jeff
Old Apr 23, 2008 | 01:23 AM
WestOzKLX's Avatar
I like this set up, looks sweet.
Old Apr 23, 2008 | 11:57 AM
cosmickites's Avatar
i just installed these yesterday. took about 5 minutes, all fit perfectly
http://store.cycraracing.com/stmodxrapak.html
Old Apr 23, 2008 | 12:19 PM
LD Drew's Avatar
Awesome Thx Fo the infO Kite Hanger! im gona get me sum of these ., shippng to canada Sux tho. Are they that Basic to install?
Old Apr 23, 2008 | 12:28 PM
very easy
it only lets me do one pic per post. i must be doing someting wrong
[IMG]local://upfiles/8953/2891DB0EBBFA4B91951AE9F6036F2675.jpg[/IMG]
Old Apr 23, 2008 | 12:29 PM
another
[IMG]local://upfiles/8953/F7341B2E44984ADF8CC0168164FD4E48.jpg[/IMG]
and one more
