2006 KLX 250 low power up top
Picked up a used '06 KLX 250 with low miles, looks mostly stock besides a pipe on it. It seems a little low on power. I thought about it being a small cc bike, but it doesn't seem to want to rev past 6k rpms... and when it does, it doesn't make much more power and it takes forever to wind out, feels like bloody murder! Haven't revved it past 8k yet... can't imagine going to redline at 10,500pms...
The bike has a "Big Gun Evo X Series" pipe on it, and the previous owner said he did a small jet change on the carb for the pipe, but...
I think I read somewhere on here that these bikes run a little lean from the factory ? I wonder if this bike isn't getting enough fuel up top...
Anyone have a recommended jet size for this pipe? I don't know much about this carb type or bike yet at all. Or is this just how these engines run?
Here's a spreadsheet that may give you some clues about other owner's jetting.
http://api.viglink.com/api/click?for...Busp%3Dsharing
The bike could be lean or rich enough to prevent maxing out RPM. You probably want to pull that carb and see what's in it. And when you say it won't go past 8K rpm, is that in any gear?
Welcome to KF.
Welcome to KF.
Here's a spreadsheet that may give you some clues about other owner's jetting. http://api.viglink.com/api/click?for...Busp%3Dsharing
Any way to monitor the AFRs or anything?
Dynojet Jet Kits - Offering Motorcycle Jet Kits & ATV Jet Kits
OOOOHH..
