1993 KX fork swap
Old Apr 20, 2016 | 09:28 AM
queen of spades's Avatar
The green background and tiny text makes the page very hard to read. Also the PDF for making the axle sleeves is not available (or wasn't last night).
Does Brewster sell these axle sleeves? He wrote $40 above but I don't know what his order page is or if I need to paypal him?
Old Apr 20, 2016 | 05:44 PM
Brewster's Avatar
Try pushing Ctrl and + (plus sign on number pad) to increase size of text.
Click on FABRICATION DRAWINGS at the end of the first paragraph.
Ride on
Brewster
Old Apr 22, 2016 | 04:17 PM
MattyTracks's Avatar
Originally Posted by zomby woof
Search KLX/KX fork swap, you'll find a good thread on thumpertalk.
I have a set of those forks and may be willing to part with them.
I may be interested...pm me
Old Apr 28, 2016 | 02:35 AM
93 fork legs arrived. Anyone have a source for the cartridge holder tool?
I'll try running the 112.5mm KDX pull rods to even out the ride.
Old May 15, 2016 | 03:07 AM
DR2KLX's Avatar
I had an 03 KX 250 2 stroke, that thing had terrible suspension. It would probably be even worse on a heavier bike.
Old May 15, 2016 | 03:39 AM
SteveP's Avatar
Just a thought, the pirelli mt43 trials tire is 1" taller....and has a cult following for being a great tire...I know i will get them when i save up a little money. And with gold valves and springs available the klx shocks should be fine for any thing a klx should be reasonably doing.
Old May 15, 2016 | 02:51 PM
Sweet, can't wait to see how this works out.
Old Jun 4, 2016 | 03:40 PM
  #28
Quick follow up. The 93 tube bottoms are not a direct match. The brake side is different
1) caliper mount holes on the 93 forks are about 1" closer together
2) has identical axle mounting setup as the 07 right side fork (cap with four 6mm nuts). I would need a 93 axle assuming the length is right.
The biggest obstacle is the caliper mount which looks not compatible.
Old Jun 5, 2016 | 02:36 AM
  #29
Ok I forgot that the axle adapter is available (or plans to make your own).
That leaves the brake caliper mount. The KLX300R / 93 KX250 fork swap page just says to use the KLX300R caliper. Clearly the KLX250S won't fit (see pic above).
Old Jun 5, 2016 | 03:26 AM
  #30
Here's a 93 KX250 brake caliper, more or less rotated to the correct position:
Pogiboy
May 6, 2012 02:46 PM
denkiblue2
Mar 9, 2012 04:14 PM
jimmy101
May 10, 2010 12:03 PM
johnnyz62
Feb 11, 2009 05:04 AM
sfog
Jul 16, 2008 02:37 PM
