13 Tooth Sprocket for 2009
Old Jan 14, 2009 | 09:09 PM
002197rp's Avatar
Hey roverdude
Thanks for the quick comeback and for your positive comment to me. It's all good among friends .... and I've always thought of you that way!
It looks like Sail-A-Way is still searching for a solution. Let's see if we can get out of the way of the one that has the right answer for a stressed out member.
Hang in there Sail-A-Way. It looks to me like Cliffsta has an '09 with a 13tooth CS. What did he have to say about your common issue? Doesn't the '09 have the shoulder cast on the 13 tooth CS like the '06/'07's have????
Old Jan 14, 2009 | 09:15 PM
Tmoe's Avatar
Originally Posted by Sail-A-Wai
come on guys - the 2009 KLX is not the same spline in the drive sprocket as the 2007 back
ANYONE found one for the 2009 ONLY
Rik
I have a 09klx, here is what worked for me.
Got it from RockyMntATV.
Old Jan 14, 2009 | 09:34 PM
Sail-A-Wai's Avatar
Tmoe
What brand is it - I called again and they said "DUH!!"
Old Jan 14, 2009 | 09:39 PM
002197rp's Avatar
Well, "ain't that special??"
But, Sail-A-Way, didn't you say that you had the #34213 part ..... and that Rocky Mountain didn't have one ... ? I'm 'gonna stay glued to this thread 'cause I've just got too see how this is finalized!!! Cliffsta said that is where he got his 13T CS.... didn't he?
Old Jan 14, 2009 | 10:01 PM
09KLXowner's Avatar
Banned
ok guys, why make this so hard? this is perhaps the easiest mod to do to the KLX and so many make it so hard. I have an '09 and have had an '06 as well, and I can attest that both bikes are identical down there. you can fit any Ninja 250R front sprocket or any Honda XR650L front sprocket. That's all you need to know. If you go around searching for sprockets for the KLX250S, you won't have much luck.
denniskirk.com has moose brand for around $15, I've bought two of them for both my bikes. the '09 splines are NOT different than the '07 like someone stated. the nut is on there hard, but if you can get some leverage it will come off in solid and quick jerk. if you try and muscle it off gradually, it won't move. a quick jerk/snap and it loosens right off. the sprocket you put on should have a shoulder that sticks out on one side- this goes towards the engine. if it doesn't have a shoulder, you've got the wrong sprocket. you shouldn't have to "machine" any part of the sprocket either. I still do not understand why this mod is so confusing to some. Perhaps a sticky needs to be made about what sprockets fit. finding part #'s makes it too confusing, if you search for the two bikes I already mentioned, it's a lot easier as those two bike are very common. good luck.
Old Jan 14, 2009 | 10:40 PM
Tmoe's Avatar
Tmoe
PD = Primary Drive.
http://www.rockymountainmc.com/produ...#vehicleSelect
The part is for a 07 but it fits the 09, like 09KLX said, "they are the same down there".
Old Jan 15, 2009 | 12:39 AM
BigFatRat's Avatar
*Sigh*
Ok, let me repeat my self.
I have an 09 KLX 250S.
This is what I ordered through the dealer catalog
http://sunstar-mc.com/searchresults.aspx?ProdNum=34213
I had the dealer install it for me. It took 30 minutes at about $50.
The countershaft sprocket in that link works for an 09 KLX 250s GREEN
....may not work for the red ones. ;P
Old Jan 15, 2009 | 03:35 AM
  #28
cliffsta's Avatar
No, I put a 14-tooth replacement on the bike, but I ordered for the XR650L because RMATV didn't list the stock 14 for our bikes. My gearing is 14/47.
However, I now see they offer a Renthal stock replacement 14 tooth for 21.99. Huh. They didn't have that a month ago.
And to clear up some of the other confusioni: A month ago, RMATV listed the PrimaryDrive front sprocket for the 09 KLX250 in 11/12/13 tooth sizes, but not the stock 14. NOW, they do not list the PrimaryDrive front sprocket for the KLX.
RMATV does not list a 13-tooth countershaft sprocket for the '09 at the moment.
MotorcycleSuperstore lists the AFAM 13-tooth for the XR650L as unavailable at the moment.
Very interesting. Apparently everybody bought 13-tooths at the same time LOL
I hope that cleared some things up, sorry if I added to the confusion.
Old Jan 15, 2009 | 03:48 AM
  #29
MaverickAus's Avatar
Originally Posted by athan
ohh i see, thx.... thank god, i just put the in my RM cart LOL.. XR650L? which year? why in rm i just only see 14th and 15th cs sprocket available?..
@maverick
one klx in my place use 48th kx250f rear sprocket.... good fit and nothing wrong happen...
well duh .... how do you get to the back sprocket when the OP was asking about the front?
To the OP sorry I did assume the 06 and the 09 were the same. My mistake
Old Jan 15, 2009 | 08:00 AM
  #30
athan's Avatar
Originally Posted by MaverickAus
dont know that a kx sprocket will fit .....
sorry, but it just my response to a question before... maybe if the rear fit, and then the front will follow ..
ok so the final answer for cs sprocket is klx 07 or xr650l (currently out of stock everywhere)...
