09 Seized Motor
Old Dec 28, 2012 | 11:12 PM
mmmbeefy's Avatar
I got the new "Head Assembly" - it didn't include cams or valves (a guy can hope, right?)
I'm now in the market for cams, I guess I might as well get some performance parts now, right?
As for valves, I'll tear down the old parts and see what's reusable.
Old Dec 28, 2012 | 11:50 PM
durielk's Avatar
You can go "track" cam & nice valves. If the cams locked up with the valves open, they may be damaged.
Old Jan 24, 2013 | 03:11 PM
mmmbeefy's Avatar
"Track" cams? please explain...
Old Jan 24, 2013 | 05:06 PM
darkmarc's Avatar
I think yoshimura makes cams for the asian market "D tracker" basically the same as our klx, with some differences, timing etc. do a search for
" kawasaki d tracker".
Old Jan 25, 2013 | 10:16 PM
durielk's Avatar
track... as in race track... web cams make'em
My recommendation is Don't go max high rpm max HP.
Old Mar 25, 2013 | 12:32 AM
mmmbeefy's Avatar
Default New Head assembly
Reassembly of the new head has begun. Much of the valvetrain was salveagable, but I cannot get the lower valve spring seats out to save my life - any tips on getting them out?
Old Mar 25, 2013 | 02:40 AM
RimBender's Avatar
are you talking the washers under the springs/ I usually just use one of the those telescoping magnets but have not done the klx.
make sure you also blow out all those oil lines and check the oil pump housing the impeller lives in. Found motors where the housing was worn enough the pump couldn't make pressure, needed new case 1/2 or jb weld buildup. Suspect your motor may have just had the oil filter installed wrong or the oil plug fell out or something stupid simple.
Old Mar 25, 2013 | 03:21 PM
mmmbeefy's Avatar
Yeah, the parts sheet shows it as a little plate. It will spin, but not come up or out. I tried magnets, grabbing it with needlenose pliers, and even putting hot oil on it and digging it out. No luck.
Thanks, will do.
Karitane Pete
May 5, 2013 04:12 AM
dazdh
Jun 28, 2011 11:39 PM
edhammac46
Jan 6, 2011 08:29 AM
kx slaughter king
Dec 7, 2008 11:30 PM
01kx125
KX125
Sep 28, 2007 03:03 AM
