'09 ran rough after crash. Thoughts?
Old Sep 11, 2012 | 01:48 PM
bcliff's Avatar
Default '09 ran rough after crash. Thoughts?
Hey guys,
I'm looking for some thoughts on my problem. I've got an '09 with a stock engine that I've never had any problems or hiccups. I was riding it pretty hard in the trails last week and took a good spill. No visual damage other than some scratch up plastics. After gathering myself, I started her back up and she ran fine for about 5 minutes. After that, the bike would bog out over 4000 rpms. It would start fine and run fine at a couple thousand rpms but anything over 4000 and she would hiccup and sputter. We checked fuel lines, breather tubes, opened up the lines, petcock, anything that may cause a restriction...nothing helped. I ended up trucking the bike home. After it sat for a few hours, she ran fine. Any thoughts?
Old Sep 11, 2012 | 02:05 PM
WAG a sticky float or some little piece of dirt stuck in a jet that has since fell back out or passed through. My first thought was a breather tube but you checked those...
Old Sep 11, 2012 | 03:04 PM
This would be my first thought too. Debris can settle in the bottom of a float bowl and stay there without incident. However, you take a good spill that really shakes up the fuel bowl and lets the stuff resting on the bottom get pulled into the needle-and-seat or the main jet, and...there you go.
Old Sep 12, 2012 | 03:07 AM
Blackheart58's Avatar
Either a bit of blinker fluid leaked out through the flux capacitor, or your muffler bearings were knocked askew. Sitting for a while allows the fluid to self-replenish, and a good cooldown allowed the muffler bearings to twist back into correct shape.
Or, it was just a Gremlin that visited for a while. When you are lucky, they get bored and leave quickly. Hopefully, you got one with ADD. Don't carry Ritalin in your gear, or, he may return, take some, settle in, and stay a while. Those semi-permanent Gremlins are usually only cured by a complete tear-down, or, selling to another owner...at which point the Gremlin leaves and the new owner never has another problem with the bike again.
Although it's hard to really tell what went on with your bike, this should narrow it down to the most likely scenarios.
Old Sep 12, 2012 | 12:23 PM
bcliff's Avatar
thanks. you've been a tremendous help.
Old Sep 12, 2012 | 12:56 PM
Old Sep 12, 2012 | 01:43 PM
cmott426's Avatar
Originally Posted by EMS_0525
Don’t buy from those guys. I bought some Muffler Bearing Grease from them and they sent me this. But I ended up using it anyways.
Old Sep 12, 2012 | 10:42 PM
wildcard's Avatar
On yourself or the bike ???
daren1093251
Sep 13, 2013 05:04 PM
trev0006
Jun 14, 2011 06:15 PM
09KLXowner
May 26, 2008 07:49 PM
Smorphine
Ninja ZX-7R
Mar 31, 2008 02:50 AM
Q500R
Ninja 500R
Feb 17, 2007 03:30 AM
