09 KLX w/ 09 Full Muzzy and 09 Dynojet no power!
Old Nov 12, 2008 | 04:13 AM
  #81
redpillar's Avatar
The two big washers that came with your exhaust pipe are for when you run your bike without the quiet core you install one washer to take up the space, and when you run without the spark arrestor you install the other one to take up the space.
There is no gasket on the exhaust outlet of the barrel that I saw. You mentioned that your air box is getting hot?
  #82
09KLXowner's Avatar
Banned
Oh good lord I gotta chime in on this one..... Start over with a 128 main, needle set at two clips and just two turns on the screw....if you can not get the bike to perform much better than stock with those settings you installed it incorrectly.
99% chance it's the needle.......obviously a bad diaphram install or hole can affect this as well. Take pics of how you are putting in the needle....this is simple sheet, gotta be sumthin stupid. Btw you got a good seal on the connections on either side of the carb and the carb itself right? Vent holes are clear?
hey, if you're gonna plagiarize my post/advice, at least cite me will ya?
Old Nov 12, 2008 | 04:17 AM
  #83
This thread is over 8 pages on jetting....no F'n way I read it ..... you said it first you get credit because that is the only correct answer.
Old Nov 12, 2008 | 04:19 AM
  #84
jpaul310's Avatar
Hey je2000, those big washers that came with the muzzy is just to keep the silencer from rattling when you remove the spark arrestor. You put it in between the end cap and the silencer.
Old Nov 12, 2008 | 04:20 AM
  #85
redpillar's Avatar
Old Nov 12, 2008 | 04:22 AM
  #86
jpaul310's Avatar
Hey redpillar beat me into it! Anyways, your airbox shouldnt be touching your headpipe! Mine was at first but then I loosened up the header bolts and removed the springs and I twisted the head pipe until there was clearance! Hope that helps!
Old Nov 12, 2008 | 04:45 AM
  #87
Damn this thread is all over the place....funny stuff.
I only checked the last two pages of this thread, but if ya'll are talking about muzzy fit-ment just grab your pipe bender and put a lil tweak in the section by your footpeg and then one more just a little down stream....no problems. Good footpeg and the rest is good to go.
Old Nov 12, 2008 | 05:14 AM
  #88
redpillar's Avatar
The 2009 250 pipe is built to accomodate the footpeg. No kidding all over the place
Old Nov 12, 2008 | 03:19 PM
  #89
JasonFMX's Avatar
If you gotta bend the damn thing thats sad. These things cost 3 arms and a leg. They oughta wash your friggen dishes and drive your kids to school for what you pay for them. I don't care how much R&D goes into it, $500 for a piece of pipe and a can is overpriced. If I had some of my old tools back in my shop form when I had my old business I could make a system. I saw where a guy either on here or at thumper talk made his own headpipe and put a supertrap can on. Did a nice job too.
Old Nov 12, 2008 | 04:16 PM
  #90
he was on here.... mustang..... i saw and herd that pipe in person... great work he did.
