09 KLX Speedometer accuracy?
I endoed my husky demolishing the speedometer, and was wondering how accurate the klx250s speedometer is. I haven't had the opportunity to get the wife to drive next to me in her car so I need to get an idea what the 450 will be doing in mph/rpm wise in 6th to keep my throttle in check on the freeway/surface streets. Thanks
Mine was 5mph off. If I was doing 50mph gps, the speedo is reading 55mph. And it becomes more off as you start to drive faster than 60mph. A little needle twiking fixes the problem.
If you change front tires to anything other than the same circumfrence of the stock tire, it will be even less accurate. I did and the GPS says mine is 7 mph off. I would get it re-calibrated if it could be done cheaply..but I haven't bothered to research it...I just ignore it.
Brieninsac
03-13-2012 05:16 PM
jhoffy22
06-20-2011 05:50 AM
