09 klx 250s
Old Jun 21, 2011 | 02:52 AM
kawasaki88marley's Avatar
Default 09 klx 250s
just got my klx about a year ago love it but have a few concerns im kinda on a budget until my quad sells but the things i have a problem with is the soft suspension and the throttle response and help with this would be awsome thanks!
Old Jun 21, 2011 | 03:01 PM
Welcome to the forums neighbor! Have you set the suspension up? there are adjustments depending on what your weight is. And switching the stock front sprocket out with one tooth smaller will help a lot. Jetting and pipe will help a lot too.
Old Jun 21, 2011 | 03:10 PM
Matasickle's Avatar
Welcome..
Old Jun 21, 2011 | 03:15 PM
Biff-a-nator's Avatar
Bonus points if your KLX is red!
Welcome!
Old Jun 21, 2011 | 04:23 PM
Originally Posted by Matasickle
Welcome..
Hahahahaha......I think.
Old Jun 21, 2011 | 04:47 PM
If you weigh much above 175#, you'll likely need stiffer fork and rear springs to help with the soft suspension. The preload on rear spring can be adjusted to help some, but it's really not the most satisfactory solution if you're going to be stressing the suspension with bumps and jumps.
Better exhaust and a jet kit will help with throttle response. Some go for a pumper carb for even snappier response.
Old Jun 23, 2011 | 12:58 AM
thanks for the welcome everyone! no the bike is green and white soon to replace all the white plastics and guards with black ones! ya the only things i have done to my bike so far is put a real dirt tire on the rear hacked off the donkey tail off the rear stripped off the decals. piped and jetted it removed the stupid snorkel and those mods have made a differnce for sure i know it will never have a snap of a race 4 stroke but just need a little more throttle response. where should i start to look for one of thses pumper carbs? and for the suspension i weigh 160 or so i was told at the bike shop new springs and somone with some know how on how to adjust the dampining and all that would make a world of differnce i dont really ride track or anything with it but do enjoy a little jumping mostly enduro races. any spring ideas? i have only found one place to get the springs from so far? why are klx 250's so hard to get parts for?
Old Jun 23, 2011 | 12:59 AM
o and do you thing valving the forks would be worth it?
Old Jun 23, 2011 | 02:42 AM
Yes...https://www.kawasakiforums.com/forum...r-shock-31416/
And I and several others here have revalved the forks, and no one regrets it whatsoever. The OEM valving on both ends of the bike is really bad with the fork being nearly unrideable if you're really going to do some harsh off road.
Old Jun 24, 2011 | 01:39 AM
ya race tech was what the bike shop suggested to me i just have to get second opinion from other before i deal with them had a few problems with them in the past but there the only kawi shop for 70 miles or so
Gteeiguy
Oct 14, 2013 03:23 AM
jespo
Feb 1, 2008 02:14 AM
deej
Jan 22, 2008 04:30 AM
incabiker
Jul 3, 2006 10:56 AM
deej
Dec 20, 2005 07:35 PM
