09 kickstarter install where to get footpeg mount
I have an 09 with kicker and have replaced the peg mount a couple of times. The OEM 09 mount will NOT work, you need the old 06-07 mount which provides clearance for the kicker to rotate down past horizontal. In a pinch, you can use the 09 peg mount but your ability to use the kicker is cut way down. They both bolt right up to the 09 frame.
I had to replace the peg mount because I ride trails and desert, sometimes fast, and the rocks or stumps can reach up and grab that peg mount. It bends easy and I am not heavy, 165#.
rkutzner
Jan 5, 2008 01:48 AM
