06 klx250s electrical issues
Old May 14, 2017 | 01:45 AM
ramsey.mangus's Avatar
Lightbulb 06 klx250s electrical issues
https://www.youtube.com/watch?v=LMMg...ature=youtu.be
Right-side front and rear turn signals DONT work
Left-side, only front signal works... blinks rapidly.
When attempting to turn on right hand signals, dashboard lights momentarily "Phase out" for a split second.
Headlight is non-functional.
Tail-light & brake light works.
Have already replaced a yellow fuse. (Numbered "20")... No effect.
Turn signals worked before going riding one day, didn't work after.. the headlight has been dead for awhile..
When I installed the aftermarket signals you see in the back, all the lights WORKED, but still blinked rapidly.. hmm..
Old May 14, 2017 | 02:52 AM
outrecording's Avatar
Check to see if the non-blinking front light bulb is out. When I made up some diy removeable turn signals, if I removed one signal and turned them on, the others would blink real fast.
When you installed the new rear signals, (I'm assuming they're LED?) did you also install a load resistor or something similar? That would explain why they were flashing fast from the beginning.
Old May 14, 2017 | 02:53 AM
I didn't install anything of the sort. x_x
calchef
May 16, 2013 03:26 AM
grady1966
Jun 8, 2011 06:01 PM
Pastor Dude
Jul 7, 2009 06:36 PM
bumpy
KLR250
Dec 19, 2007 10:47 PM
smokeater3194
Jul 26, 2005 03:45 AM
