06 250s click noise on startup now I got no power.
Went to show my friend the bike. Turned the key, lights came on & when I tried starting it, I heard a click and the light shut off. No electrical power whatsoever, From what I’ve read it’s the battery, starter relay or the solenoid?
Yeah, a clicking for the starter is normal for a dead battery and it probably used up whatever small amount of power it had left. Easy to check the fuses under the seat as well but just a dead battery is the most likely.
I checked the fuse in that black module above the seat, where’s the other one located? Also you know any decent batteries for it? Thanks a ton
