`09 Rake Confusion
Old Sep 30, 2008 | 01:15 AM
WestOzKLX's Avatar
Originally Posted by Kawi Wawi
Plain and simply - they done f*cked up by getting rid of snail adjusters.
The "mx style" screw adjusters are so prone to A) getting the heads rounded off and B) threads getting frozen in the swingarm after several years of oxidization...
Stupid, stupid, stupid.
+1 on that thought. The design is f@#kin' stupid. All the guys I know have to mod the bike straight out of the shop. (Drill a hole in the swingarm under where the adjuster bolt enters, so they can spray CRC/WD40 after every ride. Hindsight. "you won't seize up on me this time you f@#ker...Grrrr."
Old Sep 30, 2008 | 01:16 AM
WestOzKLX's Avatar
Arrrrrh. Normal service is resumed. No to wide posts. LOL
Old Sep 30, 2008 | 01:34 AM
I have to agree with Iowaguy on this one. What's the big deal? I've used both and personally I find the MX style easier because you don't have to adjust anything after removing the rear tire which I do for tire changes more frequently than I do chain adjustments. As for seizing, just use some anti-seize on the bolt. I use this stuff:
Personally, I found the snails to be somewhat clumsy to use, get one side right and it would slip out of position while doing the other side. Needed three hands. On the up side, as long as you matched up the numbers, you couldn't mis-align the rear wheel. With the MX style adjuster, I just count the threads and make them the same on either side. Same difference.
Old Sep 30, 2008 | 02:29 AM
Kawi Wawi's Avatar
Yeah, I guess if you owned your bike from new, you could take pristine care of your screw adjusters.
But I've had a few used MX'ers (CR's, KX's) that have had seized and stripped adjusters...
Always hated em. The snails are easy - just use your knee to keep the back tire tensioned against the snails
while you set their position, then snug up the axle nut.
Old Sep 30, 2008 | 03:32 AM
Einfahrt's Avatar
Wow. I ask a technical question and get snail-cam obsession.
Serves me right. I started it. And yes, I love them. So simple....
So, um, anybody know about the rake?
radmaximus
Classic Sportbikes
Apr 30, 2008 02:25 AM
Tim Mundy
Ninja ZX-9R
Oct 9, 2007 06:15 PM
Rick
May 14, 2007 03:11 AM
Rick
May 9, 2007 11:54 PM
02kawipawi6
Jul 28, 2006 02:47 AM
