@)@@ KLX 300 footpegs
Old Aug 1, 2022 | 02:07 PM
Mick-f's Avatar
Default @)@@ KLX 300 footpegs
Looking for recommendations on footpads with removable rubber inserts.
Thanks
Old Aug 1, 2022 | 04:02 PM
Thanks
I take it you mean pads for the foot pegs. Click here
Buy the rubber inserts that bolt into the foot pegs for the KLX300SF supermoto. Ball park around $10 each. You can probably pick up some spacers at a hardware store instead of buying the $6 Kawasaki spacers, or possibly even stick an 8 mm nut in as a spacer, also buy the metric bolts at the hardware store rather than the $5 factory bolts.
If you know the dealer where you might order the pads you may be able to get M6-1.00 x 20 bolts for a significantly lower price or they may have some left over in the service department, they're used in crates and such. I used to have a box of them. I have bought small metric hardware like that at a local old school hardware store or at the local Ace Hardware. I know the hardware store has the bolts, most likely even the flange bolts and will have some sort of spacer or I'd use the nuts. Don't buy the black hardware if you do get it at some store, get the zinc coated if you can. Won't rust easily, the black will rust too soon.
Hope that helps.
bamwjt
Nov 6, 2021 02:57 AM
kawi boy
KLX300R
Jun 8, 2008 02:33 AM
dan888
May 30, 2008 09:18 PM
wallace
KLX300R
Feb 22, 2008 03:41 AM
espacef1fan
Aug 22, 2006 03:40 AM
