Low OIL!!
Old 09-11-2007, 05:04 PM
Keith Tobberman's Avatar
Default Low OIL!!
I checked the oil on my KLR 650 a few days ago and I couldnt even see the level on the glass gauge. I had to tilt the bike to almost laying on the ground, then the oil filled the window. Before draining it when I changed it, I poured about half a quart of engine oil cleaning oil in. I let it idle for about 3 minute, then drained everything. Before I added the fixer, I had been riding almost everyday with at most a quart. The bike was running fine. I cant beleive I didnt check the oil more often. The bike (even though it had a quart or less) had sythetic, so that may have helped. I changed it yesturday, with synthetic, and I took it for a ride and it ran perfectly. It runs about as good as my dads 2001 with 8,000 miles and mine is a 2001 with 45,000 miles.
Is it possible that my bike suffered no damage. My thoughts are that, its running as well as ever, so if I keep the oil topped off and clean, than the engine should suffer no problems. Am I right?
-thanks
Old 04-20-2008, 05:39 PM
durden's Avatar
Default RE: Low OIL!!
Im not a mechanic, but as far as im concerned you should be fine. My KLR would burn up lots of oil riding at high speeds, I would often stop and notice the oil had dropped very low, but nothing ever went wrong. Keep an eye on it in the future and dont worry about the past.
powerband
08-06-2010 02:53 AM
06kawi420420
05-15-2010 01:18 AM
je2000
08-11-2008 08:34 PM
jon_chew
08-30-2007 08:11 PM
Quick Reply: Low OIL!!
