KF Help & Suggestion Center Need help with KF? Ask. Have a suggestion to better KF? Tell us here.
Kxf clicking noise
Old Apr 22, 2014 | 05:07 AM
Cowasaki's Avatar
Default Kxf clicking noise
I have recently bought a new 2014 kx250f, on my second ride it began making a strange clicking noise in the low rpm. It only makes this clicking noise while the bikes motor is put under stress not while at idle.
Old Aug 25, 2014 | 01:52 PM
kawa's Avatar
from what youre saying it sounds like your having the same problem i had and it was the shims and timing chain .... re shim the valves to spec and see if that helps it might be a worn timing chain too just check if the tensioner is tightened to spec if yes try moving the chain up and down in and out if it does move with out applying allot of force it has worn out
Hubert2012
Ninja ZX-7R
May 22, 2012 12:12 PM
09klx
Mar 11, 2012 02:25 PM
Post
Sep 18, 2011 01:42 PM
unnoku
Apr 19, 2010 05:19 AM
FuryofGreen
Aug 24, 2006 06:26 AM
