Performance CDI for KDX200
Old Sep 13, 2018 | 11:16 PM
jaguar57's Avatar
Default Performance CDI for KDX200
go to www.dragonfly75.com/moto/kDXCDI.html to read about how the stock CDI is designed to lower power at high RPM and how my CDI can be set to counter that problem. And if you just want a normal CDI you an set this one for standard timing. Also it can counter the offset timing that happens when you install an aftermarket CDI which almost always causes timing advance throughout the whole RPM range.
Old Sep 14, 2018 | 02:09 PM
dragonfly, your link goes all 404 on me. No good.
What does it do for a 220?
Old Sep 14, 2018 | 02:27 PM
jaguar57's Avatar
OK now the link is fixed.
both the 200 and 220 have ignition timing that detunes the high RPM power a bit.
Old Sep 14, 2018 | 05:26 PM
Still doesn't work for me....
Old Sep 14, 2018 | 05:30 PM
jaguar57's Avatar
Adjustable replacement KDX 175/200/220/250cc CDI
I think many people are scared of harming their engine by changing the timing. But they don't realize that when the timing is too advanced (such as with the KDX) then the power that would of been used to spin the crank faster is now partially used as extra psi on the rod and crank bearings and engine heat. So by retarding the timing to where it should be causes the bearings to last longer and the engine to have less stress by heat.
RayCour
Feb 3, 2014 01:01 AM
dngrrngr
Jan 12, 2009 08:49 AM
RaceGass
Dec 26, 2008 06:13 PM
2k1w=no$
Oct 23, 2007 09:31 PM
tomcat
Mar 26, 2006 12:06 AM
